Originally Posted by Just Doo Me
Ebay has 2.5" 3" and 3.5" angel eye fogs I was looking at.
I used 60mm Halo-Rings. So 2.3 "
Marilyn 2023 RTL Red
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
Lamonster
I used Lamonster's fog lights and rings with the BRP heat shields to give it a more finished look. The heat shields are inexpensive, about nine bucks each. You can try to cut the blank plugs with a hole saw, but I didn't have good luck. Lamonster's kit comes with everything you need for the installation except the heat shields, his kits are pretty much plug and play.
