Results 1 to 11 of 11
    Mar 2018
    mississippi
    Default Passenger Armrest
    Just bought a 2015 Spyder RT Limited it has these armrest on it
    It is attached with three bolts, I am assuming that there is a nut on the other end. Apparently, one of the nuts have come off and the bottom of the armrest swings out. Can someone advise me on how to get to the back side of the mounts?
    I am guessing the whole speaker mount will have to come off.....
    Sep 2016
    Chillicothe, Oh.
    I had those on mine for a summer. Mine didn't mount with a nut on the inside. Holes were drilled into the housings and then a rubber insert with metal threads was inserted into the hole. When you tighten the bolt it will swell the rubber insert and hold the armrest tight. Mine worked fine, but alas She Who Must Be Obeyed wasn't happy with these particular armrests.
    2015 RT , Black
    Mar 2018
    mississippi
    Quote Originally Posted by Navydad View Post
    What armrest did you go to?
    Isn't that set of armrests from Rivco?
    Try looking them up online...
    If they match up: give them a call, and they should be able to send you the mounting instructions.
    Good luck!
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by SOlsenPHS View Post
    Haven't replaced them yet. I chose those and since she was not happy with them she will have to choose the next set or go without. Doesn't matter to me since I don't use them.
    2015 RT , Black
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Default Passenger Arm Rests
    I have been thru Corbins, VERY expensive and poor quality. Show Chromes, not bad, reasonable price, but she didn't like them too much. I now have the BRP arm rests and so far so good. I recommend the BRP's
    2022 RT Limited , Silver w/ Black and Purple accents
    Mar 2018
    mississippi
    Good luck!
    Thanks for the advice Bob, I called them today and they are sending me replacements free of charge.
    Thanks again
    Sep 2015
    Parkesburg,Pa
    They mount with a rubber insert with a sleeve that expands when tightened,just don't over tighten or the sleeve will come loose from the rubber.I see you already called rivco and they are sending replacements.I had did the same thing when one of mine came loose.
    Thanks again
    I'm glad that my first "guess" worked out okay...
    You can get the same armrests through Ultimate Seats as well. They would have been my next choice for information.
    Active Member OKey's Avatar
    Apr 2017
    Davis, Illinois
    Default Question
    Navydad, what was it that she did not like about the arm rests???? I'm looking at getting rests for my 5' 1" wife soon.
    ........." It's a Great Life if you don't weaken' ".........
    "You don't stop having fun when you get old...
    you get old when you stop having fun"
    " Remember, Aging is Mandatory...
    Maturing is Optional "
    2014 RTS Limited , Matt Grey
    Sep 2016
    Chillicothe, Oh.
    My wife is 5'2" and she felt they were too high. Things like armrests are a personal preference so maybe your wife will like them. I may try a set of the Show Chrome rests. I can modify them easily if she wants them lowered. I don't know if it may be possible to mount the Rivco's lower on the speaker housings or not.
    2015 RT , Black
