Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Jun 2011
    Kerrville, Texas, USA
    Default How long can I leave my Spyder in the garage without starting it up/taking it out?
    Title says it all, but some context:
    - Going on a long (non-ryding) trip, our Spyder will be unused for about 25 days
    - Spyder will be staying home in our building's parking garage -- it's private, covered and safe, but no electricity drop to our parking spots, unfortunately, so...
    - No battery tender possible, and
    - No putting it up on blocks, etc.
    Happy to listen to why I should somehow overcome the latter two limitations (I would probably agree), but am mostly interested in knowing if I need to arrange to have it started up and maybe taken around the garage while I'm gone, or if I don't need to worry. Spyder is a 2017 RT bought new in December, and has had the initial 3000 mile service done recently.
    If you recommend starting it up and running it a bit, how long should it be run to do the battery charging justice, etc.?
    Thanks in advance for your input.
    Regards,
    Bret
    2017 RT-S Orbital Blue
    BajaRon Anti-Sway Bar
    SpyderPops LED Bumpskid, Spyclops II LED, Full View Turn Signals & Belt Guard
    Sena 20S Bluetooth Headsets
    Brake Free Helmet Light
    FOBO Bike for Trike
    Rugged Geek RG1000 Safety Plus Jump Starter/Air Compressor
    Lamonster RAM mount/Techmount TechGripper
    Drink2Go Cup Holders
    UltraGard Half Cover
    2017 RT-S , Orbital Blue
    Twenty five days should not be a problem if you have a good battery. Ride it good to have it all charged up before the final "sleep" park.
    A battery tender would be good if you could run a long extension cord--???
    Other suggestions will come along.
    Sep 2013
    Johnson, Vermont
    For winter storage (November - Late April) I park the Spyder in a heated garage, add some Stabil to the tank, and put the battery on a tender. Never had a problem. For 25 days of non riding, personally I wouldn't do anything.
    Default Well....
    for that length of time you should be fine. I do that from time to time and it fires right up. Make sure you don't leave anything plugged in that can drain the battery fill the tank and your all good.
    ​2012 RS sm5
    Enjoy your trip!
    The bike won't even know that you left!
    Dec 2015
    Oakley Utah
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Twenty five days should not be a problem if you have a good battery. Ride it good to have it all charged up before the final "sleep" park. A battery tender would be good if you could run a long extension cord--???
    2014 RTL Platinum
    Bossier LoUiSiAna
    Quote Originally Posted by bhern View Post
    IMG_6257.jpg No power no problem FYI found @ tractor supply. Rather than trusting someone else with your toy: only 25 days you should be good if is a good battery & charged before you leave. When you get back have some cables handy anyway, just in case. Or a jump pack
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member crazycanuck's Avatar
    Dec 2008
    Bellevue, WA
    I left my 09 RS alone in the dark for over a year due to its bad behavior, it started up with no issues.
    Jul 2010
    Las Vegas, NV
    Default No problem
    If there is sunshine, a solar maintainer is an option. 25 days is nothing if your battery is charged up.
    Joe Meyer
    Default Charge or not
    I have a 2014 RT and have had battery issues since I day I bought it ( long crank times ).... So after getting a mini lithium charger I have been waiting for the battery to fail - no luck yet ..... So when I brought it in for the Winter I decided not to put it on a Maintainer ..... well 4+ months later I started it up and it started fine ( go figure ) .... So I haven't been able to test the charger yet ..... ...............Mike
    Mike,
    If you really want to give something a test: hook a couple of large Vise Grips to the terminals, and have them stand up vertically...
    Then: toss a large metal screwdriver down into the cradle created by the grips!!
    But order your next battery first!
    Sep 2009
    La Valle, WI
    It should be ok but for Peace of mind you could disconnect the negative battery cable.
    2018 F3 Limited , Oxford Blue
    Vermont
    Winter storage..... from middle of Oct. to first week-end in April mine is in a heated garage, battery tender/maintainer, full tank of gas, oil changed. No problems.
    Be sure to let your insurance company know about the storage.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Sep 2014
    USA
    I haven't started mine since Nov until last Saturday. It will be fine. I did have a battery tender on mine too.
    But I would disconnect the battery for long periods without a battery tender
    Jan 2018
    Tennessee
    It should be good. Our RT has set for over a month and started right up. Had a new battery installed almost a year ago and it did fine. Like others have said disconnect the negative cable if you feel better about it setting that long. Good luck.
    Default BATTERY ISSUES
    Mike,
    .... Bob, please don't give anyone ( actually just some ) any idea's ....some of my views cause some people to go Apoplectic ........................Mike
    Very Active Member NautiBrit's Avatar
    Jun 2008
    Buckeye, AZ
    Since you have an RT, it's a simple procedure to remove the battery and put it on a tender in your home.
    George
    2017 BMW R1200R
    Sep 2017
    Durham,Maine
    hey, I'll come over and take it for a spin for you!! It will be fine for that length of time, but I would help you out if you was a little closer to Maine! Have a good trip!!
    2012 RTL , Pearl
    It's good for them... It knocks the scale off of their arteries!
    Active Member Don'tPanic's Avatar
    Oct 2017
    Pennsylvania
    Default a month is fine
    According to user manual Can-Am recommends charging battery after a month of not riding. Anything before 30 days is fine. Remember, the battery discharges at a rate of about 1% / day. You don't want the battery drained past 50-60%
    Jun 2017
    Hackettstown NJ
    Cool 5 months of winter
    After a long cold and snowy New Jersey winter (5 months of winter ) ......I came home from work early to day and uncovered my '16 F3-L, inserted the key and said a prayer, turned the key, and was pleasantly surprised by the computer coming to life. NOW how do I start this thing?? ECO... Starter... no... kill switch.. starter... reverse.... throttle.. BUZZZZZ. what the (oh parking break). Give me a few days to get the hang of this again
    Jun 2011
    Default Thanks again for the input on this...
    Returned from our trip yesterday, and fired up the RT this morning for the commute to work -- everything worked fine (and I managed to stay upright in the seat after over three weeks of no Spydering) so I appreciate everyone's reassurance that the down time was not going to be a problem. Looking forward to getting out on the open road this weekend, hopefully.
    Regards,
    Bret
    FOBO Bike for Trike
    Glad that you're back, and that the bike is fine!
    So... How was your trip??
    Jun 2011
    Default Trip = Great!
    It was really great. My wife and I have done a fair bit of work with people and organizations on the ground in Eastern Europe to encourage/strengthen marriages over the past decade, so we were over in Ukraine, Slovenia and Hungary. Part "working vacation," part reconnecting with friends, and part pure tourist fun -- it was our first time in both Ukraine and Slovenia, and Budapest is our favorite city on the planet. Thanks for asking.
    Regards,
    Bret
    FOBO Bike for Trike
