Results 1 to 14 of 14
    Mar 2018
    mississippi
    Default Driver backrest recommendation
    Just bought my first Can Am. Got a 2015 RT limited. I have put about 400 miles on it and I have decided I definitely need a backrest.
    Please give me some recommendations?
    Look up Utopia. The 14's and up should have a plug in the seat that the Utopia can be put through. Earlier versions had to be installed through a cut in the seat. Less expensive than the BRP version.
    Active Member rick_w's Avatar
    May 2013
    NE Ohio, Madison
    Quote Originally Posted by SOlsenPHS View Post
    The most popular we have is the Big Bike Parts Version. For the price you can't go wrong.
    http://store.valueaccessories.net/Sm...mSpyderRT.aspx
    Rick
    Spyder Lovers Vendor
    Value-Accessories
    Default Backrest
    ............ Every touring bike I have ever owned has had a Utopia on it .... I've tried the BRP ones and they can't compare to Utopia's ..... plus the price is a Lot less ......... Mike
    Aug 2012
    Central Coast, CA
    I have the stock backrest with the stock seat. I got the backrest on the secondary market, so I got it at a very reasonable price. I like it just fine, but you do have to shim it on the base to change the angle slightly. No big deal, just a couple of washers, but it is something that I consider a must do.
    2020 RTL SE6
    I like the BRP Backrest...
    Nowhere
    I chose to put a Utopia on my RT. Height and angle adjustments, matching the color and stitching on the seat, all for just over $300. The BRP backrest didn’t adjust when I was looking for a backrest but that function can be added now but you are still paying $450. Your choice.
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
    I added the rake-adjustable bracket to mine (Actually: BrentC added them for me...). It really made it MUCH easier to get comfy!
    Mar 2018
    mississippi
    I went with the Utopia...My ship date is April 9th. I am looking forward to installing it. I hope it is not to difficult.
    Default The Utopia
    ...... I've installed quite a few on 2014 and up RT's if you have any questions ....I most likely have answers ......let me know ..... Mike
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Your seat should have a knock out that comes out, then you need to get the OEM back rest to fit in it and it also comes with the mount that goes on the bottom of the seat
    2022 RT Limited , Silver w/ Black and Purple accents
    May 2016
    Traytown NL Canada
    Default driver backrest
    Quote Originally Posted by campermac View Post
    OEM backrest, after looking at my dollars for a year I sprung for the BRP backrest and it is very comfortable.
    INDIANA, USA
    Default Driver Backrest
    The BRP Backrest is what I installed. The instructions made for a very easy DIY option for me.
    ENJOY YOUR LIFE WITH A SPYDER
    Jun 2014
    ny
    I got the brp for mine
