Results 1 to 25 of 35
Thread: Clock on Dash
    Mar 2018
    mississippi
    Default Clock on Dash
    I have a 2015 RT Limited...I set the time on the clock and after a couple hours it lost 10-15 minutes. So it is always off by 10-15 minutes. What would cause this?
    May 2013
    Apex, N.C.
    Not sure about the clock loosing time, but on the RSS, RT, and F3T that I owned, the clock gains about 2 minutes a week. Maybe someone else can help you with the loosing of time. Welcome to the forums.
    That clock has never been accurate, and I just hope that the new version might be...
    Aug 2008
    MA & NH
    My clocks have never been very accurate (always fast). Seems that could have been straightened out by now.
    Mar 2015
    forrest above Reno, Nv
    Thumbs up analog clock
    The standard clock is so small. I mounted an analog clock on a dash mount ( like the one JT sells), works sooooo much better.
    Lew L
    2014 RTS , Circuit Yellow
    May 2014
    Beaverton, Oregon
    Hi SOlsenPHS,
    Re: What would cause this?
    In a nutshell, typical junk parts that Can-Am puts on these motorcycles.
    Jerry Baumchen
    My clocks are not spot on, but close enough. The big discrepancy is over the long winter sleep. Usually about 5 minutes off. The 's are attached to battery tenders from Oct/March-April for the big sleep. I just put them on the money after the first ride and they are usually good for the season--within a minute or two.
    If this happens all the time for you--it might be a sign that a new battery is needed.
    to the club. I see its your first post.
    Feb 2012
    Spring City,Utah
    JT I looked thru your website but could not find a clock. Did I miss it or are you no longer selling this item?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2015
    Oakley Utah
    2014 RTL Platinum
    Mar 2015
    Default OPPS
    I didn't want anyone to think that JT sold clocks, he does not as far as I know-------- BUT he does sell a bar that mounts on the dash. I copied this bar and mounted an analog clock from "Formotion" along with mounts for the GPS.
    Lew L
    Apr 2014
    Beloit Kansas
    It's hereditary...just like every Spyder before it. BUT... you got a really funky stereo anyway.
    Jun 2017
    Hanover Ont Canada
    I agree mine is the same.
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Lew L View Post
    Lew L
    Thanks for the follow up
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    My Spyder clock gains a little time but I rely on the GPS clock.
    Sep 2016
    Chillicothe, Oh.
    What's a clock?
    Never mind. I Googled it. I haven't looked at one for six years
    2015 RT , Black
    Faribault, MN
    What's a clock?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2016
    Willis, Michigan
    The clock on my 2015 RT-S is as useless as teats on a bull. Has been since day one.
    Dec 2008
    Syracuse, NY
    Lew L
    Lew.
    I have a formotion; it's EL/ELA style. Have you changed the battery yourself? If you have the EL/ELA style, how did you get the back plate off?
    Default Cheap chip.....
    Though I only use it as a reference, therefore never really knowing how far off it might be, someone explained it once as a cheap chip/part they could upgrade but don't. When I Ryde time is not important...
    Mar 2015
    Thumbs up
    Quote Originally Posted by wyliec View Post
    Lew.
    I have a formation; it's EL/ELA style. Have you changed the battery yourself? If you have the EL/ELA style, how did you get the back plate off?
    I'm not sure what kind of clock my Formation clock is but:
    A pair of needle nose pliers, wide open will fit into the groves in the back cover and open it. Just be careful---- gloves are a must.
    Lew L
    Active Member scarecrow's Avatar
    largo, florida
    My clock used to be. Up before sun and in when the street lights came on, but I was a lot younger then. . Now I stopped fighting with the one on the dash xand just take the wife along to tell me when to home.
    2014 RTS , Cognac
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Bob - Only time will tell
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Nov 2013
    Central Texas
    Mine goes wonky after winter hibernation. Usually off by about four hours.
    Aug 2013
    Northern California
    I have complained about the cloak and the external temperature gauge, my wife told me I could have saved a lot of money if I had just bought a watch and a thermometer.
