Took off 2 bros JB now sputters in first
So to try and get it and keep it out of going and staying in limp mode I replaced the spark plugs and removed the juice box. I know removing that would make it ride different. Well in first gear at a red light it sputters and you got to really give it gas then it just takes off like a rocket after it made a backfire noise. Is this normal? Now I have to check my left side led lights because they go dim then come back on. Didn’t mind the 2 bros JB. Just didn’t know anything about setting it up
I would say the backfire and hesitation is being caused by an intake leak. Sounds like its sucking too much air at low RPM causing a lean condition. MAKE SURE YOU PLUGGED THE O2 SENSOR BACK INTO THE OEM HARNESS!!(SEE STEP 9 IN MANUAL BELOW) You need to check the intake boot carefully for cracks. The cracks wont be visible unless you squeeze the boot. Replace the vacuum lines while your at it. Your on the right track though. Also, since you removed the juice box, be sure to start the bike and let it idle for about 20 minutes so the computer can re-adjust.
https://cdn.shopify.com/s/files/1/13...60685422644018
SPUTTER
Didnt let it idle for 20 mins but rode it for atleast 30 mins. Is that the same thing? Starting to think a bike with 7k Miles has a lot of issues
Originally Posted by BLUEKNIGHT911
Only reason I have the 2bros stuff is because it came with it.
I do remember plugging the o2 sensor back in. And if it has leaks I would think it would be sensitive like it usually is and go back in limp mode
NO
Riding it and letting it idle does not achieve the same result. Try starting it, let idle for 20 minutes(go watch tv or do dishes), then shut off, restart and should be good. BUT, BE SURE YOU CHECK THOSE OTHER PARTS!!! Your issues are minimal in my opinion and once fixed, you will have many trouble free miles.
I also did NOT have this problem till I took off the juice box. So either it’s I didn’t sit the the boots good enough in place yesterday OR it’s because the fuel mapping totally changed because I took off the juice box.
IDLE - ING
.... NO .... the computer has to re-learn the intake and exhaust parameters & unless they stay static ... they get confused .......that's the short version of WHY ...... Mike
THOSE NEW PARTS
I figured that ..... but sometimes you get the OEM stuff from the previous owner ...... Mike
SPUTTERING
So maybe. Just maybe that’s the cause of the low rpm sputter then
I always (?) try the least difficult fix, first ..... Because of the other things you have done, this may NOW be the fix, but maybe not ..... I don't think you changed to the BAJARon spark plug wires ....Yet ???? .......... But that is a bit of work ..... and those wires should last the life of the bike ..... Mike
Also. When I change the spark plug wires. Where is a good place to get them?
Ok after 11 mins it cut off so had to restart . So do I start the 20 min idle timer over?
And as it’s getting hotter it keeps shutting off while sitting here letting it idle
I would say it is an intake leak. Check the boot for cracks and check the 2 vacuum hoses carefully for cracks. Definitely acting like a vacuum leak/intake air leak. No codes?
those wires
Go to the Home page where the Vendors are .... click on to BAJARON 's Ad ....He sells the best, just scroll down to the wires and get the set for your model ...... Mike
SPUTTERING
While the JB was on and it would idle fine until it would goto limp mode no codes
would come up. Took off the JB and NOW it idles rough BUT atleast it has speed and will do 80mph instead of 50. So the 6 screws around the intake in the air box maybe the issue? Guess I need to re look at those. Never had I had anything with so much issues. And where are these vacuum hoses you keep talking about? It runs fine I guess until low rpms
CODES
" Limp-mode " is something that will show on the screen Automatically ..... 99% of CODES won't .... you have to ask the computer to show them ...... Sorry but I have forgotten the button sequencing ( pressing which ones in what order ) to bring them up ...... someone here will assist on that ...... Not likely the screws imho ..... Mike
So this is my question. Let’s say it’s a small air leak and as you see run crappy at idle. Would it hurt it to just ride it?
Come to think of it. I do remember a tiny hose that wasn’t connected. There were 2 of them. I reconnected it back though. Gonna go double check on it but not today. Today is a lazy day
SAFE TO RIDE
