Drain the gas tank
Good morning everyone, just a little bit of snow here in Chicagoland but that's okay I just sent my ECU out to be flashed.
I'm supposed to run at least 91 octane when I ger it back and I might have 89 in her now. What's the easiest way to drain the gas tank?
Thanks, Mike
2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
Will it ever stop--NO
dont
just top it off with 91 or 93 youll b ok
SpyderLovers Ambassador
Drain Fuel Tank
Use a siphon and remove what you can. Then add the NEW fuel.
ENJOY YOUR LIFE WITH A SPYDER
Or add a dash of Octane booster and the 91 octane of the future!
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Interesting....🤔
All of the above....but does make you wonder why they don't have a drain plug on the gas tank. Used to be you could pull the fuel line off the bottom but now with all the techy stuff they suck the gas from the top....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Thanks everyone, I had a pump from an old kerosene heater and I used it to pump most of the gas out. I was afraid that there was a screen block to keep anyone from siphoning gas out. I had thrown away the heater but kept the pump. Thanks, Mike
