Does anybody Sell an Adapter...?
... that will allow you to plug your Battery Tender into a USB port?
The RT has ports in the top trunk that only supply recharging power for accessories: no data transmission.
Would it be possible to lug a Battery Tender Jr into one of them, and keep the battery topped-off?
No
USB port is 5V and the battery tender is 14V. Install a tender cable in the trunk if that's where you want it.
2018 F3 LIMITED
Battery Tender has many different accessories one of which is a USB. I also have a Battery Tender
accessory that will plug directly into my heated gear pig-tail that is connected directly to the battery. Very
simple then to maintain or charge battery without opening the "frunk".
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Too small....
need the old cigarette ligter connection... or as mentioned above make a new connection to a choice location....
2012 RS sm5
NO.....for several reasons.
A USB port puts OUT power and is not designed or intended to have power going the other way.
And as mentioned, the voltages don't match either.
And they probably aren't hot when the ignition is off either.
AND.....my RT came with an SAE power connector already attached to the battery up in the frunk.
If yours doesn't have that it should be a simple matter to attach one there.
Just put the adapt. cables/plug for the batt. tender on the batt. posts and call it done. When I'm done with the adapter, it goes behind the liner and it does not come out until winter. You may have to notch the battery cover for the adapter, but no big deal. Mac
Two Options: (on a 2018 RT Series)
1) Put a 12 Volt Power Port in the rear Trunk on the right side (left side has Dual USB). Run the proper sized wire to the battery.
2) Front Trunk has a wired connection point on the Left Side next to the battery that can come out from the opening that is covered with a rubber grommet, you just need to plug a 12 Volt plug into the existing wires.
Cruzr Joe
Thanks, Joe.
Those are about the two options that I've boiled this down to; now I've got to decide which one to use.
USB NO NO
this is what i did to utilize my battery tender....
i unplug the radar detector, and insert the battery tender plug...
Dan P
SPYD3R
Use this
Here is the connector you want. I have one of these connected to the Spyder and one on the boat battery. Most chargers come with the matching end and a set of clips.
https://www.ebay.com/itm/Motorcycle-...IAAOSw5utaUtxa
This is exactly what I use
Originally Posted by JFD
easy way to use a battery tender
2016 RT-Ltd
Bajaron swaybar
Spyderpops trunk light
Elka stage 2 front shocks
Extra longbrake pedal
brake modulator
Centramatic wheel balancers on the front and rear.
Rivco dual flag holder
Tricled mirror turn signal indicators
with American and Texas flags
Lamonster Magic Mirrors
missing belt guard
Lambskin seat cover from Smokey mountain sheepskin.com
Tricled 360 degree led Headlights
Lamonster led fog lights
Baker air wings
2019 Silverado Duramax dually
2019 Cyclone 4007 toyhauler
Spyderpops bumpskid w led light
Rivco brand footrest
spydermanexhaust.com exhaust
had my exhaust installed @ Spyder in the hills.
Thanks for the link!
SpyderLovers Sponsor
YES
Originally Posted by Motorcycledave
Cycle Gear $12.00
Wrong.
He wants to connect a charger to his battery by going IN through a USB port.
Ain't gonna happen.
I have a 2011 RT and my tender is pluged in the 12 volt plug on the left side of the back trunk. It charges good there
