Results 1 to 20 of 20
Thread: Air filter
    Active Member Rookiespyder's Avatar
    Jun 2017
    Hanover Ont Canada
    Default Air filter
    I have 15000 miles on my 2015 RT Limited at what point do I change my air filter.
    2015 RT Limited
    Default Manual says.....
    Inspect at 6,000 or one year....inspect and or replace 12,000 or two years...I like the K&N filters. They are washable and go much further between inspections. There are other better replacement filters out there as well. This is data from a 2012 RS but I would think they are similar.... your manual should tell you....
    ​2012 RS sm5
    Sep 2009
    La Valle, WI
    All 1330 RT is around 19000 miles along with brake fluid change.
    2018 F3 Limited , Oxford Blue
    Jul 2014
    Mint Hill, NC
    I don't want to hijack the thread but look at pg 120 of your operator's guide. You will note there also that you should also change the fuel filter at 19,000 miles. If you however check the maintenance schedule for a 2016 RTL on pg 126 of the operator's guide you will see that the fuel filter should be changed at 28,000 miles, not 19. I specifically asked BRPCare about the change and was told to ask my local dealer -- big help! I did ask the dealer explaining that the part numbers for the fuel filters for the 2014 and later RTs are exactly the same. Dealership told me I could extend the interval on my 2014 to 28K. I missed the 19K change and ran the original to 23K with no ill effects.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Apr 2017
    North Central Florida
    I don't.
    There is a good reason why they go longer between services: They trap less dirt.
    Guess where that missed dust GOES ??
    There is a good reason why the ENTIRE ROAD VEHICLE INDUSTRY stopped using oil bath air filters about 50 years ago: Pleated paper works better.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Easy Rider View Post
    I don't.
    And yet we have a person who went 123,600 miles on a 2014 RT with a K&N air filter and it was fine.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Apr 2017
    And yet that is called an "anecdote" and it proves nothing.
    Even if it is absolutely true, it is only ONE case and we don't know what his intake or the cylinder wear looks like.
    Mar 2015
    forrest above Reno, Nv
    Default here is another" anecdote"
    I've put K&N filters on everything I owned for a long, long time. Some high mileage vehicles too and no loss of compression ( Yes I checked ). A scientific study----no, but with no compression loss and millions of K&N filters out there I will keep using them.
    BTW---- If you know who Malcolm Smith is----- he bought his first shop from the K&N bike shop in so. cal.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2018
    Madison, WI
    I have a K&N filter in my 2009 Ford Focus.
    Last week it passed 250,000 miles.
    Of course, this means nothing as there is no dust in the air here in Wisconsin.
    2014 RT - SE6 , Black
    Nov 2012
    North Las Vegas, NV
    [QUOTE=Easy Rider;1342706]And yet that is called an "anecdote" and it proves nothing.
    Her actually, Spyderann01
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Nov 2012
    North Las Vegas, NV
    I don't.
    So is this an anecdote too? Since the K&N really isn’t an oil bath air filter unless it has a sump filled with oil.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Idaho
    I don't.
    I question that. The main reason for any kind of switch of that sort is cost, pure and simple. Originally installing and later changing out a paper filter is a whole lot easier and less messy and overall lower cost than the oil bath air cleaners. A mechanic cousin told me 60 years ago the primary reason the auto industry switched to tubeless tires was that the tubeless one could be easily mounted by a machine on an assembly line and cost less than than tube tires. Back in the mid 50's there was nothing inherently better in the function of a tubeless vs. a tube tire. A factory manager at a Nissan plant in England told me back in 1989 that every request for a part change from a supplier had to start with the words "in order to improve the quality" or "in order to reduce the cost."
    Oh, and by the way, if oil bath is no good then why does Honda use an oil soaked foam air filter in its ATVs?
    2014 Copper RTS
    Apr 2017
    No, tests have been done. By reputable people who are NOT paid by K&N.
    If you search hard enough you should be able to find them.
    And.....the purpose of the "sump" was to keep oil on the filter strands which actually trap the dirt particles that they contact.
    K&N does not make bad products but they are mostly designed and intended for RACING applications where the main considerations are different.
    Apr 2017
    I don't know. Maybe you should ask them ??
    A paper filter is a BAD choice if it will be operated in an environment where the paper might get WET.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    The K&N topic is discussed endlessly on virtually every motorcycle forum in existence with those that hate and those that love them with very little in between. I personally do not favor them, but that's me. I will throw into the discussion something that is often overlooked. With a K&N or oil covered foam filters regular maintenance is a must not because of dirt contamination, but because the oil ages and dries out and thereby loses it's ability to trap particulars.
    2020 RTL SE6
    Idaho
    I believe the reason Honda uses an oil soaked foam filter is because ATVs are almost always ridden in very dusty environments!
    2014 Copper RTS
    Idaho
    Quote Originally Posted by KX5062 View Post
    I've always tended to use OEM brand or brands popular with auto service people like what NAPA sells. But I just ordered an air filter from Baja Ron, and he sells the K&N air filter only. I figure it must be quite adequate or he wouldn't sell it.
    2014 Copper RTS
    Dec 2015
    Oakley Utah
    I don't. There is a good reason why they go longer between services: They trap less dirt. Guess where that missed dust GOES ??
    K&N filters are pleated paper. They are not 'oil bath'. And, they are used a lot in vehicles of all types.
    I don't know where you are getting your information, but it's just plain wrong and not helpful.
    2014 RTL Platinum
    Apr 2017
    K&N makes more than one kind of filter.
    Actually, the SELL more than one kind; who knows where they actually are made.
    The most common type is advertised as a "high flow performance" type which is a mesh that needs to be cleaned and oiled periodically.
    I ASSumed that was the type sold for Spyders......but I don't know for sure.
    You can NOT clean and oil a pleated paper filter.
    My information might be incomplete......but what you said is just plain wrong.
    Jul 2014
    Mint Hill, NC
    Here's from the K&N home page, cotton gauze, not paper.
    Cognac 2014 RT-S
