Results 1 to 16 of 16
    May 2016
    New Sewickley
    Default BajaRon Sway Bar Helm Joint Links
    Anyone have issues with their BajaRon Sway Bar Helm Joint Links?
    I just took my 2016 Spyder RT Special Series in for state inspection and the 9300 mile service (only had a little over 7000 miles but the warranty is up in May so thought I would get it checked out thoroughly). I had a clicking noise develop towards the end of last season if you rocked the bike side to side and I thought it was a front shock going bad. Since I have a couple months of warranty left I wanted to get that checked out.
    The dealer just called me and told me the noise was coming from the BajaRon Helm Joint Links. He said they put the stock ones back on and it solved the problem. Other than that everything was installed properly so no issues with how I installed it.
    I put the BajaRon sway bar on at the start of last season and probably put 3000 miles on it. I really like it and it was towards the end of the season before the clicking noise developed.
    The dealer kept the Links so I am going to see what they look like and what might have failed to cause the licking noise. I will probably contact BajaRon to see what he says.
    I'll bet that they had just loosened-up at their mounting point on the A-Arms, and your dealer just stole them from you...
    Get them back!
    (The stock ones won't last...)
    Active Member robtdonna's Avatar
    Jul 2014
    Ellijay, Georgia, United States
    Could be several things causing this, Definitely contact him, he will fix you up. Remember the stock links are plastic, Ron's are defo stronger.
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
    Jul 2014
    Mint Hill, NC
    ...Get them back!
    A big +1!!! I'll bet there's nothing wrong with Ron's links.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2013
    Stanton, ca
    The clunking is a lose bolt holding the links on. Of course when they put stock ones on it fixed it because they tightened the bolt!
    Had this very same thing happen to me and I just tightened all the bolts.
    Bob
    2011 RT-S SM5 - Black
    Active Member dickgi's Avatar
    Aug 2017
    Saskatoon
    What torque are you using? Just by feel or is there a spec we should be following?
    Quote Originally Posted by finless View Post
    Bob
    May 2013
    Stanton, ca
    Quote Originally Posted by dickgi View Post
    There is a torque spec... I would have to look it up in the Service Manual. But when I installed the links I guessed it as it's tight to get in there with a torque wrench. Clearly I went too light the first time since one got ever so slightly loose to cause the clunk..
    Bob
    May 2016
    New Sewickley
    Get them back!
    They didn't steal them from me. They gave them back to me and they actually put on the stock ones at no charge. They had just sold a new Spyder and were putting a BajaRon Sway Bar and Link set on it so they gave me the links they took off the new Spyder RT they sold. Based on all that I think the dealer was pretty straight up with me. They even tried to get BRP to replace the links under warranty even thought they weren't stock... but BRP obvisouly denied the dealers request so they worked around it anyway for me.
    I need to take a closer look at them but one of them did not seem to be moving as smoothly as the other ones when I was rotating them at the shop.
    Default Here you go....
    torque spec it 18lbf.ft or 25 N.m and if I remember there was something about installing the bolt in the correct direction.
    ​2012 RS sm5
    Judge,
    Your initial post lead me to believe that you didn't get them back; I'm glad that you did!
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by Judge64 View Post
    Yep, I had exactly the same problem, Judge.......clicking while rocking side to side. Unlike Finless, mine was not fixed by tightening. I contacted Ron, who said he does sometimes get bad ones, and he sent me a replacement out to Aus. I ran the original BRP in one side and Ron’s in the other with no issues for a few months.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member tehrlich's Avatar
    Jul 2015
    Spicewood Texas
    I check the links regularly and tighten.
    2015 RT Limited: Fox Shocks - RonJon swaybar and links - BRP Comfort Seat - BRP Triaxis handlebars - Yokohama tires (26psi fronts 28psi back) - Centramatic wheel balancers - BRP belt tensioner - BRP Short windshield - CATdelete/Spyder1 attitude exhaust - Lamonster footpegs - sintered brake pads - LED TRYCLED lights - BumpSkid
    2015 RT Limited , black
    Sep 2017
    INDIANA, USA
    Default Loose Bolts and Nuts
    I have Not Read anything about using 'Thread-Loc'. This could be a better FIX for bolts and nuts coming loose.
    ENJOY YOUR LIFE WITH A SPYDER
    Jul 2014
    Quote Originally Posted by Little Blue View Post
    If any of that thread lock gets into the heim it will cause problems. Better to do a periodic check and retighten.
    Active Member GearHd's Avatar
    Mar 2015
    Connecticut
    I get a little bit of clicking out of ours as well but a little shot of lithium grease and it quiets them down quite a bit. They are a steel ball and steel socket so there's some slight movement that can cause a click, so lube is a good idea.
    2014 ST Limited , Silver Platinum Satin
    Default THREAD LOCK
    Quote Originally Posted by robtdonna View Post
    IMHO a person would have to be pretty sloppy with the thread locker application ...... However using a STAR washer would work also ....... Mike
