Results 1 to 14 of 14
Thread: Tech question
    Feb 2016
    HAWTHORNE nj
    Default Tech question
    I am currently using a sena 20 head set. Is there a blue tooth adapter to get the music from the radio on the Rt to the head set. If so where can I get itr, thanks....
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Yes, you need to get the Sena SM10 also sold by BRP as the Bluetooth dongle.
    2018 RT LTD , Black
    Northern Kalifornia
    Default Get it from.........
    Dave's, it comes with the wired plug and play setup that's a breeze to install. And it's the least expensive one around.
    Feb 2012
    Spring City,Utah
    Or buy the same thing complete with the proper hook up wire cheaper from motorcycledave one of our sponsors on the home page.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2011
    Kerrville, Texas, USA
    Default Or you could use the built-in FM radio on the 20s
    Quote Originally Posted by ottawa-rider View Post
    The 20s has an FM radio receiver built-in, you activate it by pushing the phone button for 2 seconds and can then seek stations with the jog dial.
    Regards,
    Bret
    2017 RT-S Orbital Blue
    BajaRon Anti-Sway Bar
    SpyderPops LED Bumpskid, Spyclops II LED, Full View Turn Signals & Belt Guard
    Sena 20S Bluetooth Headsets
    Brake Free Helmet Light
    FOBO Bike for Trike
    Rugged Geek RG1000 Safety Plus Jump Starter/Air Compressor
    Lamonster RAM mount/Techmount TechGripper
    Drink2Go Cup Holders
    UltraGard Half Cover
    2017 RT-S , Orbital Blue
    Feb 2016
    HAWTHORNE nj
    Default DAAAAAA
    I feel so stuid right now. I totally forgot the 20 has FM ....I just want to send money... that has to be it.. Thanks.
    Danbury Connecticut
    Quote Originally Posted by MOSESS View Post
    Happy to oblige.
    Please feel free to send any or all of it my way.
    No donation is too small, no donation is too big.
    Seriously, the SM20 is pretty good.
    Many devices these days have bluetooth capability.
    IPODS, GPS and cell phones can be linked to your headset via bluetooth, either directly, or through bluetooth adapters.
    That keeps the wires, and the expense to a minimum.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Feb 2016
    HAWTHORNE nj
    Default DAAAAAA
    thank you.
    Aug 2015
    Canton, Ohio
    What he said.
    Joe
    Apr 2012
    Northglenn Colorado
    I have the blue tooth Sena SMH10R and the Bluetooth receiver from Lamonster and Sena Sees the receiver but cant connect, says not compactable. Its a bummer.
    May 2013
    Stanton, ca
    This is what you need if you want to hear the Spyders audio system in your helmet AND also your passenger if desired.
    MC Dave's SM10 – Dual Stream Bluetooth® Stereo Transmitter and cable
    http://www.motorcycledave.com/sena-headsets/
    Bob
    Danbury Connecticut
    Quote Originally Posted by Tazzel View Post
    I think you're going the wrong way.
    Lamont's bluetooth device is a RECEIVER that allows you to wirelessly connect a bluetooth audio device INTO the Spyder audio system. So you can play an ipod, or other source through the Spyder speakers.
    The SM10HR is also a receiver for the audio. It only transmits on the intercom connection.
    The SM10, either BRP or Motorcycle Dave(FinlessBob) is a transmitter that will allow you to play the audio OUT of the Spyder and into your headset.
    If you have an ipod or other device that transmits bluetooth, you can connect that directly to your SMH10R, and skip all the stuff in the middle.
    I hope this helps.
    IBA #47122
    Apr 2012
    Northglenn Colorado
    I hope this helps.
    I use Lamonster Bluetooth receiver to play music from my Phone to the spyder speakers. This works great. But I wanted to be able at the same time to hear incoming phone calls on my Sena but to be able to hear them speaking on my spyder speakers because the Sena does not come in very clear when playing music or phone calls.
    Danbury Connecticut
    Mine sounds quite good for phone calls and I have it paired directly to my phone.
    Maybe you have a faulty unit ?
    IBA #47122
