Results 1 to 21 of 21
    Feb 2016
    Atlanta Ga
    Default Can the RT fit on a certain model truck?
    Looking to buy a Truck that the RT can sit in or buy a SUV with a hitch. Any suggestions on the truck? I know which SUV I'll buy already.
    Jul 2014
    Nowhere
    Are you thinking something like a rampage lift to put the RT in the bed?
    www.ramagelift.com
    puts the Spyder in rear wheel first. The website looks like it shows a short bed pickup.
    FWIW, we use a 7 by 14 enclosed trailer to haul the Spyder. Granted it’s a heavy and large trailer but it’s been outfitted with cabinets up front to hold riding gear and tie downs along with tools.
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
    Default Truck Bed
    Quote Originally Posted by Naben View Post
    The longest bed length on any pick-up I know of is 8 feet ....the RT is 9.5 ft..... I have a Toyt. Tacoma pick-up that I made a flatbed for..... It's 7' 8" ...... However I take off the Frunk when I carry my RT ........ Mike
    Mar 2016
    Akron,Ohio
    I also have have a 7x14 enclosed trailer that I transport my 2015 RT Limited in. Safe to load and unload the Spyder. When transporting the Spyder is safe and secure!!
    2015 RT Limited Red
    2017 Harley Street Glide
    Due to the width of the bikes: you have to be above the wheel wells of the truck bed.
    But I'm not happy with the Rampage setup, because you're putting an awful lot of weight: WAY up high!
    In my opinion: it's better to just buy a trailer.
    Jul 2014
    Nowhere
    Bob, I agree. I’ve got an F250 and would not want to have the RT way up there. The trailer is a much easier solution, lower cargo cg and, if you’ve got the truck, less cost (if you go open vs enclosed).
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    here's a direct link to the Rampage product
    http://www.rampagelift.com/
    2017 F3, SM6-basic black, plain and simple
    Apr 2017
    North Central Florida
    AND.....if you are thinking of loading with a ramp, I don't think any pickup made has a bed low enough to use a ramp of reasonable length without the belly hanging up at the top.
    Quote Originally Posted by Easy Rider View Post
    Who ever said that Mike is reasonable?
    His setup does work... for him!
    As for me: I've got a Class C Toyhauler, and it JUST fits in the garage.
    Feb 2012
    Spring City,Utah
    no.
    If you want the RT to sit in the bed there is no such animal. Spyder is 5.5 wide and 9.5 long Truck beds are 8 x 4 and you still have to deal with the narrower width between the wheels.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member Merlot2015's Avatar
    Sep 2017
    Honolulu & San Diego
    Quote Originally Posted by ofdave View Post
    Nice lift! still question the cg being up so high but the lift appears to be pretty solid. Does anyone have any personal experience using this lift?
    Jul 2013
    Buck lake Alberta
    Default RT in a pick up
    Check amerideck. I have used one for my RTS for the past 5 years in my GM 2500 short box. Travelled much of North America this way. Weight and stability are not factors. Much easier and better MPG than using a trailer.
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Curious as to what SUV you are considering. We are needing to buy a trailer and a two vehicle for our Spyder and two-wheeler.
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
    Northern Kalifornia
    Default Yes....
    Quote Originally Posted by Merlot2015 View Post
    What would you like to know?
    Jun 2016
    Phoenix
    What mods did you make to make this lift work?
    Northern Kalifornia
    Quote Originally Posted by marty1096 View Post
    I have an F350 with a 9' flat bed. The Rampage fits in it with a foot to spare so I have no problem with length. An 8' bed with the tailgate down will give you plenty of length. My problem was height. Because of the angle at which the ramp loads, the higher up it has to go before it loads, increased the resistance. Therefore I needed a 3500 lb. winch rather than the 2500 lb. winch that it comes with. (safety reasons) The biggest draw back I found was the weight of the ramp. It's a ramp within a ramp, it comes apart easily into two sections. And even with that, it's a two man job removing or putting it into your truck bed,,,,,, even if you were Hoss Cartwright! I simply used a tractor to load and unload my Rampage ramp. Oh, the other thing is your hauling your spyder backwards so don't forget to remove the windshield. I bought my Rampage from a trucker who used it to haul his Harley cross ways behind his sleeper. I called the manufacturer of the Rampage to ask him questions about the ramp. He was helpful and a very nice man and answered all my question. If there's anything you want to know about the ramp, give him a call I'm sure he'll help you.
    Aug 2019
    WI
    + 1 on the no backwards. I have a vivid memory of a ride to Sturgis. Saw a motorhome with a wing backwards on a trailer with the windshield flapping like a flag. I do not recall what was keeping it connected.
    The bed height for my Pk-up was 26" …. I had 10 ft. ramps and they worked fine ….. Mike
    Jun 2015
    Ritzville, Wa
    Since the option of using a trailer came into the conversation, thought I'd share this I found on Youtube.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    May 2017
    Mesa, Arid-Zone-A
    I'll throw out another option. When I wanted to transport my RTL, I rented an open trailer from Tractor Supply. This was a trailer they rented to people who needed to transport farm supplies home from their store. The spyder fit perfectly. There was 3 inches to spare on each side and 6 inches to spare in the front and rear. Cost was $25.00 per day. A lot less expensive option for occasional use..... Jim
    Semper Fi
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    Just my .02 cents
    I brought it home in the silver trailer,has a low deck. My toy hauler does not ,But I still managed to make her fit.
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
