Results 1 to 21 of 21
Hybrid View
    Very Active Member SpyderHands's Avatar
    May 2016
    Central Florida
    Question Tank Protector Options???
    What are you using for tank protection? Wrap decals or Tank bra???
    I've seen Pete's Tank Wrap option, but thought I'd drop a line here to take a reading on what the current "go-to" may be.
    Looking for something both economical and functional.
    Thanks for your time!!!
    HAND'S UP:
    The only sure way of getting rid of bad habits is to create good ones.
    AND, by the way, this will not happen on auto pilot.
    It's time for a YOU-turn!!!
    Nov 2012
    North Las Vegas, NV
    canamspyderaccessories.com has some good options.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    May 2016
    Central Florida
    Thanks for the link. Took a look; just a bit pricey.
    HAND'S UP:
    Default TANK PROTECTOR - OPTIONS
    Quote Originally Posted by SpyderHands View Post
    Don't wear " chainmale' " pants and don't wrap your legs with barbed wire to decrease how much they slide ................ ......... just kidding ..... Mike
    Greenville Tx
    I was wondering what was the purpose of a tank protector myself. Sport bike riders use them because they lay forward on the tank, on an F3 you dont. What is a tank bra? If it is not stuck down like a wrap, dirt will get in there and do damage like sandpaper.
    2017 F3 Limited
    May 2016
    Central Florida
    Quote Originally Posted by AY4B View Post
    Multi purposes. Should you decide to hold something in that position (small bag, water bottle, etc.), it is good to have a barrier to guard against undesired scuffs and scratches. I just think $50-100 is rather expensive compared to the tank pads and protectors I’ve had in the past with my sport bikes.
    HAND'S UP:
    May 2013
    Apex, N.C.
    I actually use one of the tank protectors from canamspyderaccessories.com. It works very well, and only cost about $30-40. You can find one similar at a place like cycle gear, but they will normally not be as big, and not give as much coverage. I do not like the thought of using a tank bra, as it would be too hard to remove when cleaning underneath it. I also thought about doing a clear vinyl wrap, but I decided on the pad instead.
    Default PROTECTION
    OK I'll be serious and hopefully helpful ..... I have found numerous types of clear adhesive material on E-bay, that can be shaped using a heat gun or high temp hair dryer ..... There is thicker types that they call door and sill protective material ... I'll look and see if I've saved any of those links in my e-bay file ...... Mike
    May 2016
    Central Florida
    Cool
    I didn’t see any on the site for $30-40.
    Using a tank bra isn’t an option for me. I’m looking for the vinyl pad “wrap” type of application.
    Thanks for stopping by!!!
    HAND'S UP:
    Harrington, Australia
    We are all different shapes and sizes, AY. Because of my leg length, my knees rub on the F3-L painted ridge where the tank top joins the sides. As such, I need some kind of tank protector over that edge to prevent scuffing the finish. That is where I put the clear protector pieces that came with the F3-L (the ones that you are supposed to put on the frame near your boots)
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    I have always wondered what the clear pads were for that come with your bike from the manufacturer.
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Active Member always young's Avatar
    Oct 2015
    Melbourne, Fl
    Default Tank protection material.
    I wonder what that clear plastic stuff that comes with your limited is, never got them? Anyhow, doesn't matter. What I used on my bike as well as the previous one was a clear plastic material that you can get from any sewing store (Joanne's, Micheal's) for pennies. It's in the fabric section and comes in various thicknesses. Cut it to shape, takes experimenting to get a flat wrap shape, wet it, apply and squeegee it out. The surface adhesion holds it in place. It stays real well and can be taken off easily without leaving anything behind. Not cheap, just frugal..... Of course, the ones you buy do look a whole lot nicer but this is transparent and not noticeable. Just another alternative.
    May 2016
    Central Florida
    HAND'S UP:
    Durham,Maine
    What about body piecing's?
    2012 RTL , Pearl
