Results 1 to 8 of 8
Thread: 2014 oil change
    Mar 2016
    Lakewood, Illinois
    Default 2014 oil change
    Would like to learn how to do my own oil changes on 2014 ST Ltd but havent been able to find any info other than shop manual. Does anyone know of any instructional info anywhere. Thanks
    Dec 2015
    Oakley Utah
    Quote Originally Posted by peddy View Post
    Lots of threads and YouTube videos on that topic. Did you try searching?
    2014 RTL Platinum
    Mar 2016
    Lakewood, Illinois
    Thats were i looked first but didnt find anything specific for ST....
    Feb 2012
    Spring City,Utah
    Isn't the ST the same VTwin as the 2010-2013 RT? If so other then the removal of the plastic it should be the same. You can find the skin removal sequence in your owners manual.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default Try this
    Re-check for the GS/RS/RSS they are all the same as the ST when it comes to an oil change. The RT is got different panels to deal with but the engine is the same.
    ​2012 RS sm5
    Oct 2015
    Lynden, WA
    Use this video for the oil change on the GS/RS and ST. Worked for me on my 2013 ST.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jul 2017
    Florida
    That video must be for the manual transmission. The semi-auto transmission has an additional filter that is replaced with each oil change.
    Active Member GearHd's Avatar
    Mar 2015
    Connecticut
    The full instructions for an ST are right in the owners manual, they tell you all the panels that need to be removed, oil quantity and torque specs. It's very easy to do. None of the panels that need to be removed are difficult.
    2014 ST Limited , Silver Platinum Satin
