Results 1 to 8 of 8
Thread: 2017 RTL
    Sep 2014
    Fremont, OH
    Default 2017 RTL
    I anticipate signing the papers on Tuesday for my new 2017 RT Limited, trading a 2011 RTL. YEAH for ME! My question is....after reading through all of the forums, I haven't seen much if anything good or bad on the 2017 RTL. Is this a good Oman or bad?
    Looking forward to Spring in 6 weeks and the chance to ride, actually the wife wants it more than I think I do, both spring and the bike.
    Thoughts????
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    seventeen, schmeveteen.. If it wasn't broke in fourteen, it shouldn't be broke now.
    You are gonna be okay, you'll wonder why you waited. Happy trails !
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Danbury Connecticut
    I think you haven't heard much about the 2017 because there were no groundbreaking developments.
    The 2014 went from the 998 V twin and introduced the 1330 triple.
    2017 had some different colors and a few more usb power connections.
    The next big development was the 2018 glass dashboard.
    I'm not wholly convinced that was a good idea, since the glass dashboard seems to be dependent on a smartphone and third party apps.
    Still, I imagine you could still hook up a Garmin GPS and ipod if you wanted to be a bit more independent.
    You should be fine with the 2017. Quite fine indeed.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Newflover View Post
    Thoughts????
    I got a 2017 model in late 2016. I have put over 22,000kms on it since. Only issue I had was after going on a 50klm dirt road, we hit a torrential rain storm, and mud made the black light sensor stick, causing the nanny to act up. Once cleaned, everything was great.
    I have no complaints with this bike at all.
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    INDIANA, USA
    Default 2017 RTL
    I have the 2016 RTL and there was very little change to the 2017. .BUY, RYDE and ENJOY
    ENJOY YOUR LIFE WITH A SPYDER
    Member Kipawa's Avatar
    Apr 2017
    Elk County PA
    Default 2016 RTL
    Thoughts????
    I have a 2016 RTL and couldn’t be happier with it.
    Fox Front Shocks
    Baja Ron Sway Bar
    Chrome Side Wind Deflectors
    Chrome Handlebar End Caps
    Spyder Flap
    Ultimate Seat/Backrest
    Spyderpops Bumpskid
    Powerlet 12V Outlet
    Techmount Techgripper / Value Accessories Handlebar Ram Mount
    Perma Grin
    A great example of if it isn't broke, don't fix it.
    I have a 2014 and have not felt the urge to upgrade for the same reason.
    The change from the 2011 to the 2017 is good. You get the 1330 engine and less prescribed maintenance. We also currently have a 2011 RT.
    I think your going to like it.
    May 2016
    Ontario, Canada
    Only problem with a glass dash W/ the Gps built in (on a car as well) is if it goes for a poop you have lost all your way points and if out of warranty out a lot of money. On the 2017 if the Garmin goes POOF you can still "usually" plug it into a computer and up load your info , buy a new garmin and down load your info into the new one. I had my car garmin screen go poof - couldn't even tell if was on - plugged into the home computer, uploaded to gamin's site and down loaded back into a new garmin. Just say'n and just food for thought.
    Johnny
