Results 1 to 25 of 25
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default ECU removal - where's the tabs to release the 2 wiring connectors?
    Hello, I'm trying to remove my ecu and I can't seem to locate the tab to unlock. Where exactly is the tab to push to unlock. I've attatched pics. Also is a pic or a brass knob by the ecu. What is that?
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Dec 2013
    The brass knob is the headlight aiming adjust for that side headlight - you'll have a matching one on the other side for the other headlight!
    As for the tab to press in, you can't actually see the tab in your pic cos you are looking at the side of the clip, not the face. So, look at the bottom right of the clip in the pic you showed.... you can see a placcy bar heading 'into the pic' & across to the other side of the ECU... the tab is what stops the middle of that bar from moving up & around as you swing it to follow the arc of the quadrant on the top of that whole placcy clip thing, so you hafta push it IN before you try to move the bar. Make sense??
    If you could get your eye down alongside the bottom screw shown in your pic, and look to the left of the pic or directly at the clip we can currently see the side of, then you would see the tab quite clearly in the middle of the placcy bar mentioned earlier.... Help any?
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Active Member Doug's Avatar
    Jul 2013
    Brights Grove, Ontario, Canada
    Default web site
    Go to Monster Fuel Injection WEB SITE, they have photos showing the removal of the ECU
    2017 F3-S , circuit yellow
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Remove the 3 screws holding it to the Spyder and the use a small flathead screwdriver to depress the tab and swivel the lock
    2014 RT-Ltd , Cognac
    Nov 2015
    Tinley Park, Il
    Thanks everyone. I finally found it. It's next to impossible to see, esp in a poorly lit garage. I didn't realize that the clips are double, front and back and move together. I was looking for something to just release the front side. Thanks again. Mike
    Active Member thereverend's Avatar
    West Monroe, LA
    Default Ecu removal?
    I would like to have the reflash done on my 2015 RT SE, however when I remove the three screws, then I can not figure out the release buttons, latches etc to get it to release, I have seen the pictures of the removal but they are out of focus and do not show the exact spot to touch just a general "push here"...so is there anyone that can post a picture of the exact point of contact to remove the ECU? many thanks if you could make this happen for this old man.
    Dec 2013
    Don't have a pic atm, but IIRC, there is at least one on the Forum somewhere, if you search....
    However, the release levers for the wiring plugs are a cam-lock type arrangement, only in the centre of the cross bar on each, there is a tiny little button you hafta release by pushing first, before lifting & swinging the lever arms.
    Hope that helps some.
    Good Luck!
    Nov 2018
    Claremore, Ok.
    Is that cam-lock available individually? Broke one to pieces installing my Power Commander V.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Jun 2016
    Harrington, Australia
    This was posted previously under ECU removal. Sorry, I can’t credit who made it, but it is excellent .....
    https://bc5ea35f-0a76-4e03-8a52-544a...9d11136ca1.pdf
    Pere
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Dec 2015
    Oakley Utah
    Pere
    This pdf is from Wick-It for the Monster Flash ecu removal instructions. It is, as the O.P. posted, pretty useless.
    I can't find the release button either, as the pdf pictures only generally point to the area it's supposed to be. One picture shows the release button from the underside of the ECU but it's not in the same place the other pics show it to be.
    Pretty frustrating. Can't get light or tools into such a tight spot to see what I'm doing.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Doug View Post
    Useless.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Default 2014 Spyder RTL ECU removal
    The release tab is the one in the center of picture #4, positioned where the clumsily drawn arrow points to in #3
    2014 RTL Platinum
    Mar 2008
    Hesston, PA
    https://vdocuments.net/spyder-ecu-in...ed.html?page=3
    Look at this picture...See the MCD??? Its right inline with the D
    larryd
    Sep 2014
    USA
    https://www.monsterfuelinjection.com...9d11136ca1.pdf
    Think its the same one posted above
    Dec 2015
    Oakley Utah
    Quote Originally Posted by larryd View Post
    larryd
    Thanks. I found it. I just had to use the right cuss words.
    2014 RTL Platinum
    Northern Kalifornia
    Thanks. I found it.
    Ah ha! You got it. Took me a frustrating few minutes to get mine released.
    Northern Kalifornia
    Are you going 1 or 2?
    Dec 2015
    Oakley Utah
    Stage 2.
    2014 RTL Platinum
    Nov 2015
    Chardon, OH
    Stage 2.
    I expect a standard Navy Nuke analysis and report once you get it back and try it out.
    Doug
    ”Freedom is not a loophole”
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Snowbelt Spyder View Post
    I expect this to blow the rods out of the core and go critical.
    2014 RTL Platinum
    Nov 2015
    Chardon, OH
    Prompt critical would be worth it for the money.
    Doug
    Dec 2013
    Now that you've actually found those release tabs, can you see how the pointer in those broader view pics couldn't possibly focus in on anything that small; and the close up pic really was pointing EXACTLY to the tab you needed to press??? Couldn't really have been any clearer, could it!!
    It's just that the tab on the crossbar bit of the release is so small that it's very difficult for anyone trying to describe it/identify it in a meaningful way for someone who doesn't already know where it is &/or what they're looking for.... But generally, once you realise that you HAVE BEEN looking right at the bloody thing & bitching about the pics not showing it when they really DO point at it & show it, then it all becomes clear....
    Just like searching for anything, it's ALWAYS gonna be in the last place you look - in this instance, the pics weren't really useless - after all, they were pointing right at it but you just couldn't SEE it, cos you weren't thinking it would be something like that; or maybe it's smaller than you thought; or maybe it was just that you had the wrong glasses/poor light/the cat diverted your focus for a split instant.... . But just like you couldn't see it for looking right at it; this really should make one a little more wary on the roads & maybe a tad more understanding about those cage drivers who can look right at you, maybe even make eye contact, but still not SEE you!! Shouldn't it - cos we ALL do it sometimes/for some things!?! Some call it situational blindness??!
    Glad you found those tabs & got your ECU out; aren't you SOOO happy that yours was in an easily accessible place & not hidden away, jammed into a tiny slot between the LH front side of the placcy air intake trunking & the frame cross-member - a slot that was barely wide enough to fit the ECU into, let alone being anywhere near wide enough for you to actually unscrew & remove the 3 securing bolts so you could slide the ECU out of it's hidey hole?!? I almost hadta dismantle my 2013 RT into its component pieces to get its ECU out!! .
    Now you've just got a short (but oh, so long ) wait for your ECU to be split, upgraded, and returned/re-installed before you can finally feel for yourself why those of us who have done it already always claim that it finally makes our Spyders perform the way they SHOULD perform straight off the Showroom floor!
    Hope the wait isn't too long!
    Dec 2015
    Oakley Utah
    Thanks for the encouragement Peter. I hope my pictures will help the next person figure it out a little easier.
    As for the bitching, well .... I'm not the strong, silent type I guess. I was told in the Navy that if I couldn't get something to work it's because I wasn't using the right words....or a big enough hammer....
    2014 RTL Platinum
    Mar 2008
    Hesston, PA
    I up graded from the stage 1 to the stage 2 this year...WHAT A DIFFERENCE...Should have done the stage 2 originally...DON'T FORGET TO SEND THE AIR CLEANER LID...LARRYD
    Dec 2013
    We all do it, so I wasn't aiming that comment just at you!
    And I learnt much the same thing as you about carefully choosing the 'right words' & to 'get a bigger hammer' when trying to make difficult stuff work - firstly on the farm; then on the workshop & foundry floor; even in university & labs; and yet again when it was reinforced in the Navy here in Oz - so it's gotta have a deeper source than just being a 'Navy' thing? . Maybe IT's the Meaning of Life, the Universe, and All that Stuff, and not 42 after all??
