Results 1 to 10 of 10
Thread: 2018 RTL
    Active Member meerkat's Avatar
    Jul 2015
    leesburg florida
    Default 2018 RTL
    I am trying to hook up my Garmin to my RTL , and I am not having any luck with the wiring diagrams being too small and unreadable . Does any one have a suggestion as to where to hook up ? I thought of the driver hand heating circuit , as it doesn't get much use here in Florida , But I can't find what color it is . Any help appreciated .
    Nov 2012
    North Las Vegas, NV
    You should be able to tap switched power from the fuse box.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2015
    leesburg florida
    Default 2018 RT
    I can't figure out how to get the fuse box out . All of the hookups are from the back of the fuse box and I think the # 8 fuse in the left box is unused but can' see how to get it out without tearing stuff up .
    Why not just pull the GPS function from your Smartphone?
    The bike is designed to do that!
    Jul 2015
    leesburg florida
    Because the image is so small that I cannot see the dang thing with these old eyes .
    Jul 2010
    Las Vegas, NV
    Default Factory connection
    Under the side panel is a factory connection for the Garmin. See instructions/Brp.com
    Pretty easy. I can’t recall which side, but the process is the same; wind deflector, mirror, 3 screws, pull panel. Then 2 screws, 1 pushpin, open saddlebag, remove 3 screws. Remove lower side panel. Connection is there.
    Joe Meyer
    Quote Originally Posted by meerkat View Post
    I understand completely: I'm just about in the same boat also...
    Aug 2013
    SF Bay Area
    Why buy an '18 if you're not going to use the built in capabilities? The new dash is very clear and you don't have to glance down to the handlebars to see it. I understand its different and requires learning how to use it but once you get it, it really cool. No dash clutter except for camera and maybe CB.
    2021 F3 Ltd , Magna Red
    Sep 2013
    Houston
    Quote Originally Posted by cptjam View Post
    Not sure the 2018s have that connection any more.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jul 2010
    Las Vegas, NV
    Default Apart
    Not had an 18 apart yet, but doubt they made a new wiring harness. These are the folks who left a battery compartment in the left saddlebag 4 years after they moved the battery to the other end of the bike!
    Bob, yank the sidecovers off and take a look!
    You can find switched power in the position light. Remove right headlight. The smaller of 2 connections powers a position light. Tap into that.
    Joe Meyer
