Yes! Another tire thread...question
Looking for people who have run either the federal formoza az01 or 595 evo on the front of a F3 or F3S only please. These are my 2 choices in the stock size. I’ve read many review on these tires but all on different models than mine. It would be nice to get some feedback from someone running something similar to me. I have no problem with the stock tire as far as traction goes, just can’t seem to get the damn things balanced.
I don't have a F3 but do have a RT and really like the Formoza Tires on the front end.
I'm running the AZ01's on mine. Love 'em! Night and day difference. Made the handling light and nimble. Much better cornering traction both cold and hot at a somewhat more normal running pressure (20 vs 15 on the Kendas which made the byke feel like a truck)
I was torn between the 595EVO and the AZ01, ended up on the AZ01's simply because I couldn't locate a pair of the EVO's at the time. No regrets tho. But I like the look of the EVO's and will prob run those next. I am hard on my tires and I am wearing the outer edges off like a man possessed. Not the tires fault, just the geometry of the machine and my riding style... I did read a few (very few) reviews on the EVO's saying they were noisy and hard riding. Not sure how accurate that can be on an 850lb machine with so much mechanical linkage between you and the tires. Now when I was on 2 wheels, it was a totally different aspect....
Chuck
Thanks! That’s the kind of response I was looking for. I push my bike hard in the corners (probably harder than I should be) and I want something that grips good. I guess I could just slow down, but what would be the fun in that.
I also see you have the slower color, sorry....you should of gotten the black & chrome if you really wanted to go fast.
tire theory mis-conceptions
#1.- since Spyders only weigh about 1/4 as much as cars do ... using car tires that are designed to hold up a car that weighs 4000 lbs at the same PSI is foolish, the tire will LOSE traction much sooner. This is a Fact not a Theory ...... #2.- and as far as the EVO's go ... the kids who like to slide their cars around - known as Drifting - well the tire they say is the best for doing that is the EVO..... which logically means the tire is NOT a high traction tire, because those people Want their cars to slide ....#3.- and the outside wear on your tires is do to bad Alignment not your riding style .............. Mike
Chuck
Ding! Ding! Ding!
I didn’t mean to start a fight over this. I am an ASE master auto tech & I know that specs on tires don’t mean ****. That’s why I asked someone’s opinion that has actually used these tires on their Spyder. You can have the exact same tires on 10 different cars & they will all perform different, especially when you have a car tire on a motorcycle. Thanks for your real world experience & opinion on this Hyper, I’m going to order me a set of the formoza’s.
and the same to you.... I have 20+ years in the automotive world with many years of it in the tire industry.... and I'm gonna leave it at that....
Chuck
It's all about justification....
Richard
* 2012 RS SE5 (hers)
* 2013 ST SM5 (mine)
Daughter RSS SE5 2014
Son in law RSS SM5 2013
P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
2 sets of Kumho 175/55R15 front tires
1 set of Hankook V4
1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
Formoza
Hi there, I ride a 14' rts. I have used yokohamas s drive and what a wonderful tire. Now I use formoza on the front and back using the same size as the stock tires. Great great tire for wet or dry or hot days. I ride two up alot and it handles wonderfully, even at 85 mph.
SpyderLovers Sponsor
I have a 2015 F3s, and up until last year I had the stock Kendas until I upgraded to the same size Evos, and that was obviously a great improvement. This year I purchased a set of PPA wheels on sale, and so I went with the 175 size azo1's. Haven't had a chance to mount them yet, but pretty sure the new combo will be the cat's meow!
I'll have a set of stock rims and evos on sale soon..
BTW, I had added the Centramatic balancers, and they seemed to work for me before with the evos.. We'll see how they work with the new wheels and tires that my local shop couldn't balance because of their size.
I have a '17 F3S Daytona and one of the first thing I did was put Federal EVO's on it. They are a great, long wearing tire.
Maybe this will fix ?
Yes, I already have those & tried those. After a little bit of mix up (I removed all the weight then installed balancers, come to find out you’re supposed to leave the weight on) I had the wheels rebalanced & it seems to be worse than before. I’m going with new tires just because I’ve heard so many bad thing about the Kendra’s, thinking they may be the problem & because new tires are only about $100. I’m hoping this does the trick.
I have tried tires,balanced them several times. And believe the wheels are the problem. I finally found a place that balanced my wheels with a road force balancer and fixed the problem.
I was amazed how many tire places do not balance a wheel correctly even noticed this on my car tires too.
Also tried the centratic balancers and didn't work well, then found out to leave the weights on but never went back to try the centramatic balancers yet.
Brought this one back to life did ya!
