Remote preload adjustable rear shock
Does anyone know of a replacement rear shock that has a remote preload adjuster? They're pretty common on motorcycles and it sure beats trying to manually move the adjustment rings like on the Elka.
They are out there...
check with the Elkas, RaceTecs, Fox and there are some european shocks as well. Just have to do a little digging and know which you want. There are the built to one side of the shock and those with a hydraulic hose and adjust to mount elsewhere...
Thanks, I looked at Elka shocks listed for the ST but none I saw had remote adjusters, same with Fox -- I guess I'll need to call the mfg. to find out for sure.
