Results 1 to 9 of 9
    GOS member (Girls On Spyders) ruthie's Avatar
    Feb 2011
    Collinsville, Mississippi
    Default Bent radiators fins
    Bent radiators fins on 2014 RT. Any comments on this problems
    2014 RT SE6 Limited
    rYding Safe = Having Fun
    Ruthie
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Spyderpops has screens that will stop this from happing.
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    United States
    Quote Originally Posted by ruthie View Post
    https://www.amazon.com/ABN-Condenser...A1UMBRA5ZTBCX8
    Where and how bad? Samewok is 100% correct, Spyderpops KOTT (Keep Out The Trash) Grilles are a HUGE help.
    Feb 2011
    I have the Spyderpop screens on.
    2014 RT SE6 Limited
    Ruthie
    Default RADIATOR DAMAGE
    My .02, are based on this .... I rarely take any of my Spyders in for DEALER service ..... But I did need some warranty work on my 2014 RT ...... because I had already removed my Frunk ( for Mods ) I knew my radiators were perfect - no damaged fins etc., after getting my Spyder back from the Dealer , I had to remove my Frunk ..... and guess what I found ... Yep damaged fins on both Radiators .......... imho, the only thing that could get past the OEM GRILLS is a rock that is soooooooo small ....fin damage is not possible ...... as far as bug bodies are concerned that's even less likely , how much do think a dead fly weighs ????? .......... That's my take on the subject ....... Mike
    Bossier LoUiSiAna
    Quote Originally Posted by Roadster Renovations View Post
    Or a more adjustable one
    https://www.zoro.com/diversitech-fin...QaAiovEALw_wcB
    there is a technique to using properly for best results .
    first off go slow. & be careful the fins can be sharp you won't just get a cut but maybe 10 or more all at same time, & all with nasty blades from road gunk & bug guts. Good luck share some before & after pics if you don't mind please.
    Default Oooo..!
    I answered your other thread....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    INDIANA, USA
    Default Radiator Fins
    The fins are Sharp. Depending on the type of damage, they can be straightened. There is a tool called a radiator 'fin tool/comb'. Your local NAPA auto parts store can help you with getting this tool.
    ENJOY YOUR LIFE WITH A SPYDER
