2018 rt trailer tumbler
I didn't get a new tumbler for the trailer. Did you?
My dealer said it doesn't come with it anymore
Ozzie Ozzie Ozzie
The extra tumbler usually comes with the Spyder, not the trailer!! That's cos the extra tumbler is meant to be keyed alike to the Spyder, so that you don't need to carry around yet another key for your 622 trailer.....
The extra tumbler was included on all the new Spyders I checked out here in Aus last weekend - well, all those that have the rectangular rear swing arms & are 'approved for towing', but not on the F3's with the tubular rear swing arms (like the Daytona....) - I suspect that's just cos you aren't meant to tow with the Daytona so it's not really all that 'necessary'?!?
I just got a new 2018 RTL and it was missing the extra tumbler. I was just curious if the other people that bought a 2018 got the extra tumbler
Blazing Member
2018 F3 Limited and no tumbler !Hey I'm calling the dealer .
2017 RT-S, and I did get the extra tumbler. Good thing, as i just bought a freedom trailer.
2017 RT-S
Bump Skid - Spyderpops
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
3 PC Mesh Zippered Lid Net Set - TricLED
A arm LED's - Safety LED's - TricLED
Mirror Sequential turn signals
Glo-riders
LED rear turn signals and reverse lights
Front Grills
Third Brake light
Larson Scanner
Light Up - Sue Hopper
Tumbler
The tumbler doe's not come with the 2018 spyder rt limited . You can't get a factory CB with it either . For communication you have to go with a Sena20 S so says the can am shop . Trying to figure out all the electronics is a reel chore . meerkat
What's a tumbler? What does it have to do with trailers?
I'm hoping BRP isn't really in with Sena and that all other BT headsets are not an option? Even Sena knows that CBs are still very much in use as they make adapters for Goldwing and Harleys that have CBs. The Goldwing with Apple Car Play will have a CB and wonder why BRP thinks differently.
Thought all that went away when they stopped making the 622. As I understand the lock on freedom trailer is not changeable, different mechanism for the only door. I could be wrong, I was only interested in a 622 & couldn't get till the freedom came along & Joe was kind enough to part with the one he farkled so wellTHX again!
It won't work on the freedom trailer
Cruzr Joe
Originally Posted by Flamewinger
What's a tumbler? What does it have to do with trailers?.
A tumbler is the lock. You put your key in the tumbler and it opens
Cruzr Joe
So i just found out. The extra tumbler (lock) that came with the 2017 RT-S is longer than the one on the freedom trailer, also the one on the freedom trailer has the end of the tumbler mushroomed around the locking bar, so you can't take it off.
Has anyone been able to get it out, or re-keyed to match the bike??
Ray
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
Another bonehead move by BRP. Sounds to me like they are getting rid of trailers altogether.
Let's see if I got this correct. I buy this: Can-Am Spyder Roadster RT-622 Trailer Locking Key Barrel Kit Lockset 219400710 Take the barrel to a locksmith and have him change it to my bike key, and then follow the instructions in the video. Am I missing anything?
2015 RT-S , large brake pedal Silver Platinum Satin / Steel Black Metallic
Then call it the lock. A tumbler is what's inside the lock. You want answers, you need to describe the problem so everyone understands it.
I was told by a BRP employee that CBs are not a big thing in Canada so they stopped making the entertainment wiring on the 2018 models and discontinued the CB also. Their CBs were not much good anyway. The CB on my GW is MUCH better and I do miss it on Mr. White. I think BRP is missing a $1,000 sale.
So how do I tell if I have the old 622 or Freedom trailer? I see it's a 2015 on the VIN plate...
How many doors does it have? Freedom has 1 and the 622 has 2.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Ok, I have a 1 door Freedom trailer and I need to get an extra key made for it. Suggestions please?
Sorry late reply the most obvious difference FYI 622 has a front & back door:IMG_4202.JPG either open from same lock on the back the freedom trailer has one large door:IMG_4204.jpg hope this helps there are other details hopefully others will chime in.
Start trying various hardware stores & locksmiths shouldn’t be that hard a key, if it is the first locksmith will let you know
I went to my local locksmith and had him re-key the trailer lock to match my ignition key. I removed the tumbler and took it and the spare key in - cost was $20
they are talking about a tumbler (the guts of the lock)
