Results 1 to 15 of 15
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default Remove engine ecu
    Good afternoon, what exactly do I have to do to remove my enginge ecu? Just the panel or the mirror too?
    Snows starting to melt here in chicagoland after getting blasted. Can't wait. Thanks Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    On my F3-S the ECU is behind the left side body panel. It is mounted with 3 10mm bolts that have locktite (Grrr) can be a bit fussy to get to the top and forward bolts. The top has to be done with a wrench vs socket. The two wiring loom connectors are a bit tricky to disconnect. You have to push in at one edge of the base of the connector then the latch rotates and you must rotate it all the way down until you hear it click. Very important! Otherwise you will not get them off.
    Chuck
    Jul 2014
    Mint Hill, NC
    It's behind the L side panel, the one that says "Rotax" on it. Engine off. Remove the two connectors at the bottom and the three Torx bolts holding ECM to frame.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Dec 2013
    The 2014's & newer are fairly easy & might take as little as 10 minutes to remove! Easy as!! For 2012's & older, it's not much more difficult...
    However, if you've got a 2013 RT that's a whole different ball game!! Those are fairly diffucult to get at, let alone remove, cos their ECU is sandwiched up front underneath the remote battery terminals & behind the front cross member that the frunk hangs off but in front of the engine & all the air intake ducting!! And those 10mm screws are aimed back away from where you can get at them... plus they are about 25 mm long & on 2 of them the 'extraction space' with everything else remaining in place is only about 15-18mm!! Pulling the air inlet trunking from in front of the engine out entirely & lifting the headlight assy makes it a lot easier to get the ECU out, but doing that does take some fiddling & time & makes for a whole lot of frustration......
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Nov 2015
    Tinley Park, Il
    [QUOTE=JayBros;1336280]It's behind the L side panel, the one that says "Rotax" on it. Engine off. Remove the two connectors at the bottom and the three Torx bolts holding ECM to frame.[/QUOTE
    I see the small panel with Rotex on it but I dn see any screws on it. I'm attaching 2 pics, hopefully the right ones. I have foot pegs, does it matter.
    Dec 2014
    Lee's Summit, MO
    The left panel with CanAm and Rotax on it just pulls off. There are no screws or bolts holding it on. You will find the ecu behind it.
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by kngfsh27 View Post
    Thanks, that's what I thought and wanted to hear, I just dn want to break anything and I've heard the mirror can be tricky.
    Any idea what the rev limit is, I'm going to have it flashed and that's one of the questions. Thanks, Mike
    Jul 2014
    Mint Hill, NC
    When you remove the L side panel look at the small plastic clip on the backside of the top of the panel. When you reinstall the panel be absolutely certain you get it snapped into place on the front body panel. If you don't get snapped in place you can lose the whole side panel at a cost of about $230.
    Cognac 2014 RT-S
    Nov 2015
    Tinley Park, Il
    Thanks for the tip. Mike
    Nov 2015
    Tinley Park, Il
    Well I got it on and filled her up with 93 octane and took her for a short ride and did not notice much difference-----until I realized the rear wheel was spinning and I got up to 60 real quick and the throttle response is much quicker. Can't wait til I can really take her out for a long ride. Anyone know what to expect mpg wise? Also I thought I read that I might get better traction by lowering the rear psi. Thanks, Mike
    Nov 2015
    Tinley Park, Il
    When I put the panels back on does the solid one or the slotted grill go on 1st. Thanks, Mike
    Apr 2008
    Hi, can you share what company you used for the ECU flash? Thank you. Daniel
    Apr 2017
    corpus christi, texas
    Wick It performance
    Jun 2014
    Muskego, WI
    I'll be interested to hear what your impressions are of this mod after you get a few more miles on it.
    Rick H.
    I just noticed you did this back in April! So how has it been going?
