Results 1 to 18 of 18
    Active Member vrodrjs's Avatar
    May 2012
    Jacksonville, IL
    Default 622 Trailer Lock removal question
    I am selling my 622 trailer that is keyed the same as my bike. I'd rather not give away one of my keys with the trailer. Does anybody know if you have to have the key to remove the barrel? My RTL came with an extra lock so I am hopping others did too.
    Thanks,
    Bob
    Current Bikes:
    2018 BMW K1600 B
    2012 Spyder RT LTD - Sold
    2003 HD VRSCA (VROD)
    Jul 2010
    Las Vegas, NV
    Default Yes
    You need the key, and a barrel tool. Picture a piece of razor thin spring steel. The barrel catch is the deepest of the tumblers. Your dealer can remove the barrel.
    We learned this trick when Ann’s barrel was .05mm too deep. Naturally, I destroyed it in my learning process!!
    barrels keyed differently have a red key, no chip. Joe
    Joe Meyer
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    Pull the barrel before you sell the trailer !
    Happy Owner
    Nov 2013
    Central Texas
    Maybe you could get a dummy key cut from your Spyder key. Might work, then you wouldn't have to give up an ignition key.
    May 2012
    Jacksonville, IL
    Thanks Joe
    Quote Originally Posted by fastfraser View Post
    I thought about that but it is too cold / salty roads to ride down to the dealer and I don't really want to take the back end of the trailer apart to do it. I think a call to the dealer for a key may be easiest.
    Thanks,
    Bob
    Current Bikes:
    2018 BMW K1600 B
    Jul 2010
    Las Vegas, NV
    Default Dummy key
    With no chip, the trailer key wont start the bike. EZ! Joe
    Joe Meyer
    Bossier LoUiSiAna
    Quote Originally Posted by vrodrjs View Post
    Thanks Joe
    Thanks,
    Bob
    its really not that bad, some odd positions to reach things but not as tight spaced as working on spyder. & if your buyer has a spyder they can acquire a new core & have rekeyed by locksmith to match theirs. Once you get the lock mechanism off :
    other than that a chip less blank Ilco X270 (cut to fit)will work just fine.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Dec 2015
    Oakley Utah
    its really not that bad, some odd positions to reach things but not as tight spaced as working on spyder. & if your buyer has a spyder they can acquire a new core & have rekeyed by locksmith to match theirs. Once you get the lock mechanism off other than that a chip less blank Ilco X270 (cut to fit)will work just fine.
    Helpful. Thanks.
    2014 RTL Platinum
    Mar 2013
    Maumelle, AR
    When my wife bought her 622 trailer, she didn't get a key with it. I was able to replace the tumbler with hers without a problem. No, you do not need a key.
    2020 RT Limited , Chalk
    Dec 2015
    Oakley Utah
    I am the buyer. So, I'm going to have to replace the tumbler sooner rather than later because right now I can't lock it at all.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by cptjam View Post
    I realize that, Joe. But, with no key I can't lock the trailer.
    2014 RTL Platinum
    Jun 2010
    Las Vegas
    You resurrected a 2 year old post. Joe wasn’t responding to you.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Dec 2015
    Oakley Utah
    Quote Originally Posted by SpyderAnn01 View Post
    You're right. I was confused.
    2014 RTL Platinum
    SoFlo
    When you do a proper search of a topic, you should at least read the dates to ensure the posts are somewhat current before resurrecting topics from a while back with a new trivial set of posts.
    Use the search feature to find the information or search outside Spyderlovers with Google.com
    Sep 2014
    USA
    Really. I see no reason to blast him for asking a question or resurrecting a thread. Ask a question and hope to get a answer to the issue.
    Dec 2015
    Oakley Utah
    Actually l was following a suggested link from a response to my own thread and found it helpful, so said as much, which inadvertently resurrected the thread. Then I got confused as to which thread I was responding to.
    2014 RTL Platinum
    Sep 2014
    USA
    I was referring to the post above mine.
    Dec 2015
    Oakley Utah
    Yes, I realize that. Thanks for that.
    2014 RTL Platinum
