Shorty Antenna Installed
Finally got my shorty antenna installed last night. The adapter pieces in the kit wouldn't work so I made my own.ANTENNA.jpg
I'll always find a way.
Shorty Antenna on RT-S
I put one on my RT-S a couple weeks ago...from Big Bike Parts. It's a "fat" 7" spiral wrapped antenna and the radio works just as well as it did with the stock antenna. I went with a short one so I could get in and out of the place I keep my trike without hitting the antenna in the doorway.
I replaced a short antenna on my 2014RTS-SE6. Here is a picture of mine: New Radio Antenna on 2014RTS-SE6 001.jpg New Radio Antenna on 2014RTS-SE6 002.jpg I used a 7mm deep socket to install the new antenna.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
I've done a lot of upgrades, and the shorty antenna was my biggest surprise of difficulty! I could not get that twisted off with the thread-lock! It was one of those times where you are so frustrated that you have to walk away. Then, come back to find it twists right off!
2015 RT Limited: Fox Shocks - RonJon swaybar and links - BRP Comfort Seat - BRP Triaxis handlebars - Yokohama tires (26psi fronts 28psi back) - Centramatic wheel balancers - BRP belt tensioner - BRP Short windshield - CATdelete/Spyder1 attitude exhaust - Lamonster footpegs - sintered brake pads - LED TRYCLED lights - BumpSkid
Yup ! walking away works alot........
Ray & Marci
Tenino, WA
2014RTL Cognac
ALWAYS ride 2 up.
Originally Posted by teninospyder
Had same trouble on mine. After much deliberation about why I was worried about destroying the original antenna on our 2014 RTL SE6 (knowing full well I would never put it back on) I cut it off as low as possible, used the 7mm deep socket I had to go buy (I found most sets don't go down to 7mm deep socket) and with a little pressure the antenna base came out. Incidently, I used the shorty replacement antenna from Walmart (RSM-900, or something like that) and all the required parts were there. No other mods, just re-assemble using a few (not all) of the supplied parts. Nice and clean look
I'm glad that I am not the only one that couldn't get the jelly jar open! I was ready to bang my Spyder on the counter to get it to go!
