Results 1 to 13 of 13
Thread: Help
    Active Member rkba101's Avatar
    Dec 2016
    Green Cove Springs Florida
    Default Help
    Ok not sure if it is KAT or CAT, but a friend informed me that I should change this first before the pipe.. Looked around at our suggested and trust sales here and can not locate this item. Any suggestions? Thanks guys.. Ride safe ..
    My Ride --->>> 2013 ST-S SE5 <<---
    Oct 2016
    Faribault, MN
    Catalytic Converter Bypass pipe it's the actual primary muffler that's inside/under the bike versus the final output pipe we all see.
    Lamonster has some or can likely send you to the source for one for your '13 ST-S.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Default Try this
    Remove the cat (catalytic converter) and install the bypass pipe and see how you like the change in sound. If you need more happy hunting there are a few out there to pick from.
    ​2012 RS sm5
    Dec 2016
    Quote Originally Posted by DGoebel View Post
    Yes checked that site.. No luck.. Ugh
    Greenville Tx
    Pitbull carries them for your spyder.
    https://www.pitbullpowersportsinc.co...Id=-3774&fpg=1
    2017 F3 Limited
    Dec 2016
    Quote Originally Posted by AY4B View Post
    Awsume.. Added this to the Bday wish list for the wife.. LOL
    Either way I will get it, but this way I may get it as a surprise..
    Greenville Tx
    I knew I had seen them somewhere recently but no vender here carries them. The installation is really hard though. it would be better if you could find someone to do it for you unless you feel confident to take it on. I did mine on my ST and remember having to use the weight of the spyder to get them to go on. The old bolts to the muffler will have to be cut off. They supply new bolts.
    2017 F3 Limited
    Greenville Tx
    There are videos on Utube on how to install them, you can do a search.
    2017 F3 Limited
    Jun 2010
    Las Vegas
    Make sure you also order replacement gaskets as you’ll likely need them. They are also available at a Pitbull.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Greenville Tx
    The ad does not mention bolts included. You may want to call them to see if they are included and if not to send some. or just go to the hardware store befor you start. Do not use nylocks though. Also when I did mine, not all the springs were on my old Cat. When I called to ask why, I was told you don't need them all. I just used the 2 per connection instead of getting the 3rd one. I could feel later the heat. Make sure you have all the springs.
    2017 F3 Limited
    Dec 2016
    Default Thanks..
    Thanks Guys..
    Jan 2018
    SW washington
    Does anyone know the difference between the CAT BYPASS sold by Spyder1attitude and the one sold by Pitbull Racing that would account for the $100 difference in price?
    May 2017
    Central Texas
    Default Cut it Up
    Quote Originally Posted by rkba101 View Post
    I'm going to remove the cat, then using a hand grinder, cut the can in half. Using a hand chisel & metal bristle brush wheel, remove the contents of the cat. Then, either take is to a muffler shop or buy a stick welder and put the piece back together. I did this on my '13 Harley the shop charged me $50 to weld the plate on. If it's more that $100, I'm gonna learn to weld...
