Results 1 to 9 of 9
    Active Member Cruising RT's Avatar
    Dec 2014
    United States
    Cool Where is the paint #?
    Can anyone tell me where to find the paint number on a 2014 RTL? I'm getting ready to paint my trailer to match the bike but I'm having issues with the paint #. My Spyder is Pearl White, I think. I've looked up paint numbers and found listing for a Vegas White so I need to confirm the paint number. Any help appreciated. Read several post pointing to U S Paints but their website only shows up to a 2013 model.
    Sep 2014
    USA
    IT is vegas white I know that from buying a rear panel for my 2014 RT.
    Dec 2014
    United States
    Thanks! Just located paint codes on Lamonster website.
    Default PEARL WHITE
    Quote Originally Posted by Cruising RT View Post
    Not OEM but I haven't found anyone who could tell the difference ....... and this was done on my Pearl White 2014 RT ..... After removing the stock antennae I had to patch the hole .... I did it with a base coat and a top coat .... from Toyota .... If you are painting a trailer it's going to use a lot of paint ..... the Toyt paint can be purchased in pints ,quarts, & gallons ... also in 14oz. spray cans ............ You can see some of my work on Deanna777 posting pages ......... Mike
    Oct 2016
    Faribault, MN
    Mike and or others, which Toyota White?
    I'm finding several different Whites and Pearl Whites under Toyota?
    Crystal White Pearl
    Blizzard Pearl Tricoat
    White Pearl Tricoat
    White Color Code 45
    White color code 56
    Super White Code 40
    Iceberg White
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Default PAINT MATCHING
    Quote Originally Posted by DGoebel View Post
    Crystal White Pearl
    White Pearl Tricoat
    White Color Code 45
    White color code 56
    Super White Code 40
    Iceberg White
    Please let me make a correction first, I did this so long ago my memory failed me ... Both colors were from Dupli-Color ( a well known brand of after market paint ) the base coat was actually a FORD tinted paint termed Pure White ( which it wasn't to my eyes at least compared to the Toyt. paint ) the # is BFM0384 ........ The Toyt is White Pearl # BTY1626 , this paint is trans-lucent so the Ford color must be used as the Base color .....through trial and error I found that the Ford color was Key to a match ....... I see you listed the White Pearl ( Tricoat ) .... I couldn't find the word Tricoat on my can ( and I checked for it ) ...... I know people want stuff to match, but consider this ....#1. If the colors aren't actually touching or over-lapping ( like spot painting ) a very, very close match won't be noticed by anyone ....... and my Paint job was of the over-lap variety .......#2. the BRP paint is UBER expensive for a small amount ...enough to paint a trailer might break the bank ...... Good Luck .... Mike
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Oct 2016
    Faribault, MN
    Thanks Mike and Highwayman! I'm wanting to paint my 2013 Heat reduction scoops
    and since they are right on the body panels really do want as close a match as possible. Optionally, if I can't make a good match, then I'd wrap them in CF or something.
    Safe Rides,
    IBA 70020
    Oct 2016
    Faribault, MN
    Thanks Cruising RT, I did find the 2015 Paint codes at Lamonstergarage.com under the News and Blogs section too. Seems some of the earlier paint codes were in that post and have dropped out of the links.
    Safe Rides,
    IBA 70020
Tags for this Thread
