F3 USB port
I'm about to take the plunge on a new 2017 F3 LTD. On my current Spyder RT LTD , I have a Ram mount where the factory GPS once was. I installed a USB in the switch console to power my phone.
Any one know what my options are for installing a USB port near handlebars on F3?
IF you are planning to install a Garmin 590 GPS, one of the wires on the harness is a USB port I just ran it to the base of the phone holder and Zip tied it. Lamonster Garage also has some options as well.
2017 F3 Limited
My USB option
Hi,
In this post:
http://www.spyderlovers.com/forums/s...ndle-bar-mount
you will find what I did.
Not only my phone can be charged, but it is linked to the radio so I can listen to my music at the same time.
X-Grip Ram Mount Phone Holder, Lamonster Fog and driving lights, BRP Heated grip, Home made rear rack + Shad SH58X top case, BRP belt tensioner
SpyderLovers Founder
We have several options for powering up your phone in the F3 section.
http://www.lamonstergarage.com/lamon...3-power-plate/
There is a USB port in the glove box on top of the dash.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
When I had my F3 this is how I ran power to my handle bars for Phone and GPS as well as battery tender. When I traded in my F3 for a F3T I transferred everything over. The USB in the Dash is fine but it is made so you cannot run the power cable out to the handlebars. Its great for charging a phone if you leave the phone in the glove box or Bluetooth receiver.
Yes but it will not power a garmin. or most cell phones.
I charges my Iphone 6 Plus.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
I also have a battery pack that i purchased at Costco. sometimes when the battery gets low I would just stick it in my coat pocket and run a lightning cable under the jacket to the phone on the Xgrip. It does not get in the way with operating the Spyder and lasts several charges.. You can also take it in the resturant of wherever and go in with it still charging in your pocket.
2017 F3 Limited
It only provides 500ma which will charge slowly if the phone is not doing much of anything. If its on or being used for GPS, its not enough power to keep up with usage.
Most smart phones and the Garmin need 2A to charge while being used.
I did get a overcharging message when I tried to charge my SENA headset. Now I see why. I was on a cross country trip and i used the phone for music and in that case did a good job.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
This is what I did:
Wired it into the Customer Accessory Circuit.
2020 Harley Davidson Tri Glide Ultra
2017 F3-T SE6 White / BRP Backrest / Nuvi 58 LM / Polaris Spring Spacers / CALSCI 22" Shield
That’s what I used for my GPS power. Left side under the cover.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
