Tri-axi handlebars
How do I adjust them? I loosened them up and moved them front and back. I was also told that they went up and down. How do I know where to put them
Put them where they are most comfortable for you. Make your changes in small increments and it may take a number of tries to get them where you want. Carry the wrench with you and make changes when your body tells you to do so. Be certain to tighten them after every change.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Bummer.....
There are no pre-sets on those bars. Much like tire pressure gotta keep trying till you find the sweet spot. Everyone is different so you can't go on others adjustments....
How do you make them go up and down in height? Is there another screw besides the 2 on the top?
There is a Allen bolt under the rubber plug nearest you while sitting on the bike. Turn bolt counter clockwise to go down. Clockwise to go up.
2014 Copper RTS
There are also jam nuts under the adjuster bolt. May have to loosen and readjust to your liking.
bar
Hard to turn allen bolt is an understatement . Anyone have a suggestion on how best to loosen it up so am able to raise and lower.
Mine turns rather hard also. I find it easier to use a ratchet with am a hex head socket.
Wayne Bishop
2015 RT-S Special Series
2017 F3 Limited
Read Post 7. There are jam nuts that CAN be loosened If you like to make the adjustment easier
Jam nuts
First off the allen head bolt under the rubber cap is hard to turn. As suggested use a ratchet with an allen bit to rotate it. As for the suggestion of messing with the two jam nuts I wouldn't mess with them. They were set that way for two reasons:
1. They removed any up and down sloop/play of the handle bar by sandwiching the frame of the handlebar between the underside of the head of the allen bolt and the top of the first nut under the handlebar frame.
2. They are also adjusted to provide rotational resistance of the bolt so it don't loosen over time.
Also if you are raising the height of the handlebar Do Not raise it to the extent that the end of the bolt goes inside the brass rod that it is threaded into. You want 100% thread capture of the brass rod.
