Results 1 to 12 of 12
    Bryant, Arkansas
    Default HEY....... Don't forget
    All you do-it yourselfers when you check your oil, air pressure etc......................
    Don't forget to check your BRAKE FLUID.
    do not worry about the blinker fluid, it is self replenishing.
    Cruzr Joe
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default FLUID
    BLINKER FLUID.....????????
    is the right next to the POWER STEERING FLUID....?????
    Dan P
    SPYD3R
    Bryant, Arkansas
    Quote Originally Posted by SPYD3R View Post
    Dan P
    SPYD3R
    Opposite Side, down under.
    Cruzr Joe
    Jan 2015
    southern WI
    Cruzr Joe
    Not so fast Joe....I've found my blinker fluid low a couple times. I've had to top off the reservoir a couple times. I hope there's not something wrong with my Spyder. My reservoir is next to the windshield wiper fluid, so it's an easy job
    2021 RT Limited
    2016 RTS , Pearl White
    Active Member spyderider1's Avatar
    Jan 2018
    Wisconsin
    Low Fluid levels can cause Loose Muffler Bearings. And you don't want that!!!
    LORD GRANT ME THE SENILITY TO FORGET THE PEOPLE I NEVER LIKED,
    THE GOOD FORTUNE TO RUN INTO THE ONES I DO LIKE,
    AND THE EYE SIGHT TO TELL THE DIFFERENCE.
    2016 Spyder RTS
    Bryant, Arkansas
    Quote Originally Posted by spyderider1 View Post
    Use WD-41+ in the blinker fluid to prevent such a disaster.
    Anonymous
    Sep 2017
    INDIANA, USA
    Default Check
    ALSO REMEMBER TO CHECK THE TIRE PRESSURES FOR 'WINTER AIR'. PS: SOME LIKE IT WARMER THAN COOLER.
    ENJOY YOUR LIFE WITH A SPYDER
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Good advice.
    Active Member rkba101's Avatar
    Dec 2016
    Green Cove Springs Florida
    Default Blinker Fluid?
    If anyone needs some here is a coupon.. Free can not pass that up!
    My Ride --->>> 2013 ST-S SE5 <<---
    Bryant, Arkansas
    Quote Originally Posted by rkba101 View Post
    We like FREE
    Anonymous
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Default Checks
    Cruzr Joe
    Good to hear from you cruzr joe, have not heard anything from you in a while. At least now we all know you still exist.
