Results 1 to 25 of 33
    Springfield, MO
    Default New F3 fuel cap in the works from Lamonster Garage
    We're in the final testing stage of the new keyless fuel cap. Many of us have trouble closing our cap after fueling and this is our solution. This will come unfinshed, all black and black with accent cut like our IPS products. I posted this on Facebook and had great response but I forgot to post it here. So what do you guys think?
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    Another awesome option from Lamonster's Garage to fix a known problem !
    Happy Owner
    Harrington, Australia
    I personally love the idea that it is keyless. I’ll be getting one when they come out. Thanks Lamont.
    HeliBars Handlebars
    Kenda Kanine rear.
    Dec 2012
    Murphy, NC
    Default NEW FUEL CAP
    I do like the look but would be afraid some jerk would steal the gas cap or put some foreign object in the tank. I have had no trouble closing my cap since I sprayed silicone on the rubber gasket. Great product, though, for those that are interested.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Bryant, Arkansas
    INTERESTING,
    VERY INTERESTING
    Cruzr Joe
    Feb 2016
    Usa
    Quote Originally Posted by JKMSPYDER View Post
    Me too
    Jun 2011
    Alamogordo, NM
    Riding motorcycles all over the USA and owning well over 50 motorcycles as well as owning lots of cars and trucks for 60 years anyhow. Never had anyone mess with a gas cap in any way.
    Keyless Gas Cap sounds great.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Feb 2017
    ST LOUIS MO
    Quote Originally Posted by old Timer View Post
    i like the look i will take one
    Spring Park, MN
    Default Keyless Gas Cap
    Oh yes, I'm in.
    2016 Spyder F3-L Special Series
    2016 Spyder RT Special Series
    Active Member foxtail1's Avatar
    Jul 2017
    Virginia
    Looks good to me. I didn't know that I wasn't alone in struggling with the gas cap.
    2017 F3-S
    2010 Honda Element
    Harley map
    Spyder map
    Someone stealing the gas cap or putting some foreign object in the tank would be enough of a worry that you would not buy the product? That surprises me. Does that happen often in the US?
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2011
    Alamogordo, NM
    Short answer...............NO......
    Dean O
    Gran Pa Hoon
    Alamogordo, NM
    '20 Spyder F3 L
    NorCal - Northbay
    I have mine reserved with Jacob!
    Chuck
    Houston
    Quote Originally Posted by foxtail1 View Post
    We have had a number of them like that in our shop. Have been able to fix all of them with proper lubrication and instruction on how to close the lid.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    NorCal - Northbay
    True as did I on mine. But sometimes you just want that thing to blend in and stop staring you in the face. Powder Coating is a PITA and paint can't withstand fuel when some a-hole fills the vapor nozzle with overflow!
    Ahhhh, the things we come up with to justify some snazzy new farkle!
    Chuck
    Houston
    It is a snazzy new farkle! And if aesthetics is the reason for it then it makes all the sense in the world. No need to justify your farkle urges to me.
    Suppose I was lucky in the aesthetics area as the matte finish silver gas cap was a perfect match for my color scheme. Not so much on a triple black.
    Greenville Tx
    I was wondering how people with IPS keys open their gas lid?
    2017 F3 Limited
    Houston
    Quote Originally Posted by AY4B View Post
    Still works fine. We have a few customers that use them.
    Oct 2015
    Broken Arrow, OK
    Default Original Gas Cap - Question
    Can the Lamonster Garage share with us what they have been doing to the original caps to make them work better?
    Phil29
    Greenville Tx
    The one thing I dislike about the factory setup is having to remove the key, insert the key, unlock the lid, lock the lid remove the key, insert the key... I did not have to deal with that on my ST with a gas door. If I pull in listening to some good tunes, they will be interrupted by the whole thing. Also the key insertion requires just the right angle or it will not go in. Just pulling in and unscrewing the cap like every other motorcycle on the planet is very attractive to me.
    2017 F3 Limited
    Springfield, MO
    Quote Originally Posted by phil29 View Post
    Phil29
    Sounds like James needs to share what he's doing because everything I've done doesn't last that long.
    Houston
    Quote Originally Posted by Lamonster View Post
    TriFlow lubricant in the slide latch mechanism. Seems to last 6 months or more.
    https://www.amazon.com/Tri-Flow-TF20.../dp/B000SKY3GO
    But it is not near as good looking as Lamont's new farkle. And I agree the key hole swap dance at the gas station gets old.
    Active Member hillbillywhisperer's Avatar
    Dec 2016
    Florida
    Even though I have no issues opening and closing the gas cap using Lamonsters IPS key after lubricating the seal I still want one.
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    We will definitely be getting one for my wife's F3.
    Great product Lamont.
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    I've seen a couple of these and they are Cool
    https://www.drivenracing.com/halo-fuel-cap
    I like the flat finished look.
