Trunk Part?????
My trunk lid will not stay up. What is the part called that holds it up???? Shock, strut..........hard to be repair woman!!!
Was it staying up before and now doesn't? If so, then a replacement strut should solve that problem.
Has it never stayed up as long as you've had it? Then, consider adding a strut to the other side so there are two doing the job.
FWIW; 2013RT
2014 RTL Platinum
Honey, do you have anything mounted on the trunk lid? if not you can just replace the one or possibly adjust the mounting point. If you have added a luggage rack or something to the trunk lid that weighs it down, you might need to add a second gas strut
Here's a link to an earlier discussion Trunk replacement shock on RT trunk
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Check out this thread http://www.spyderlovers.com/forums/s...ht=trunk+strut
There are a number of threads on this topic. Search on 'trunk strut'
2014 RTL Platinum
SpyderLovers Ambassador
Trunk Gas-Charge Strut
Check with your Local NAPA Auto Parts Store. May need to Google 'NAPA' for your nearest Store. Definitely A Much Better Price Option.
ENJOY YOUR LIFE WITH A SPYDER
Thanks Y'all !!!! Appreciate that. This will get me working on that!!!
Did you get the problem FIXED?
Or.......
Originally Posted by UtahPete
Got this idea/ mod on this site:
Drill a hole about 3/4" above the original strut mounting hole and remount the strut. Cost -----ZERO. Works perfect with the rack mounted.
Lew L
