Results 1 to 7 of 7
Thread: Grease fittings
    Jun 2017
    Crossville TN
    Default Grease fittings
    Couldn't quite find the answer i was looking for when I searched previous threads. I found out that the front suspension arms have zerks on them. I am wondering if the rear wheel bearings have zerks on them. Or does the greae have to be pressed in with a bearing press? Thanks guys
    We have a 2013 RT Limited
    Dave
    Jul 2011
    Mitchell, Ontario, Canada
    No grease fittings on the rear. Sealed bearings only.
    As you discovered there are 8 grease fittings on the font A-arms, 4 per side. Those are the only grease fittings.
    Active Member R FUN's Avatar
    Apr 2013
    Rocanville Saskatchewan canada
    Has anyone tried giving the rear wheel bearings a shot of synthetic grease with a grease needle.
    Roger
    2012 RT Limited
    Vertika Floor boards
    Painted rear fender & dash
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    Elka shocks and relocaters
    CB radio
    ISO hand grips
    Tric LED fender light
    Turn signal lights in mirrors
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Quote Originally Posted by R FUN View Post
    Roger
    If you're going to go that far into the rear wheel, why not replace the bearings
    2008 GS.....PE # 2888
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    Roger
    probably "someone" has. Of course that is going to violate that bearing's seal. So when things warm up a little, it can fling the grease
    in the OTHER direction...out. Messy too.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    wisconsin
    Roger
    Why not "pop" the seal on the exposed side with a fine/flat screwdriver, rub some grease over the bearings and work it in. Then replace the seal, paying attention to make sure they are seated properly?? Mad Mac
    Apr 2013
    Thanks guys for your ideas. Just thought it would not hurt to service the bearings when have the wheel off to change a tire.
    Roger
    2012 RT Limited
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    CB radio
    ISO hand grips
