Grease fittings
Couldn't quite find the answer i was looking for when I searched previous threads. I found out that the front suspension arms have zerks on them. I am wondering if the rear wheel bearings have zerks on them. Or does the greae have to be pressed in with a bearing press? Thanks guys
We have a 2013 RT Limited
Dave
No grease fittings on the rear. Sealed bearings only.
As you discovered there are 8 grease fittings on the font A-arms, 4 per side. Those are the only grease fittings.
2018 F3 LIMITED
Has anyone tried giving the rear wheel bearings a shot of synthetic grease with a grease needle.
Roger
2012 RT Limited
Vertika Floor boards
Painted rear fender & dash
Carbon fiber panels
Utopia back rest
Baker air wings
Elka shocks and relocaters
CB radio
ISO hand grips
Tric LED fender light
Turn signal lights in mirrors
Roger
If you're going to go that far into the rear wheel, why not replace the bearings
....and we're gonna ride, we're gonna ride.....
ride like the one-eyed Jack of Diamonds, with
the devil close behind,.....we're gonna ride....
2008 GS.....PE # 2888
Roger
probably "someone" has. Of course that is going to violate that bearing's seal. So when things warm up a little, it can fling the grease
in the OTHER direction...out. Messy too.
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
Roger
Why not "pop" the seal on the exposed side with a fine/flat screwdriver, rub some grease over the bearings and work it in. Then replace the seal, paying attention to make sure they are seated properly?? Mad Mac
Thanks guys for your ideas. Just thought it would not hurt to service the bearings when have the wheel off to change a tire.
Thanks
Roger
2012 RT Limited
Carbon fiber panels
Utopia back rest
Baker air wings
CB radio
ISO hand grips
