Results 1 to 17 of 17
Thread: Smoke signals
    Active Member rkba101's Avatar
    Dec 2016
    Green Cove Springs Florida
    Default Smoke signals
    Well a month ago or so I placed a forum asking about the spyder smoking.. Had awesome replies and took it to the local dealer. Since they were going to change the oil and remove the plastic I would have them check it out. Well they did change the oil so they stated and return the unit stating no reason for it to smoke.. Drove it home in the rain that evening and parked her in the garage no smoke. Well drove it a couple miles to a nearby wing joint and POOF ! Huge bellow of smoke.. WTH! So I let her sit and no over heating, nothing.. smoked stopped so I drove it home pulled into the garage and POOF white smoke fills the garage. WTH ! Talked to a couple peeps on fb page and they suggested I remove all the plastic and take a peek. Well heck I did, and Im a nurse.. I can save your ass but mechanic um not really. So I removed the plastic look in there and I was like ya an engine.. LOL didnt see discoloration, fluids, melting wires. Nothing strange looking as I would see. I drive it around the neighborhood naked.. The bike not me.. LOL and drive up the driveway POOF smoke coming from the belt side.. I peek into the small spot under the belt and found this..
    Well showed this to the FB friends and one of them take that to the dealer. So I did.. They state "Well we can not diagnosis everything" Really miss a huge piece of plastic jammed between the belt and exhaust? Hummm..
    Bossier LoUiSiAna
    Sounds like time for new dealer. Least a report to bro cares glad you found cause of smoke but now need to double ,triple check the belt Things melted probably left residue that can causes problems later, glad your still mobile & smoke didn't ignite anything
    Default Wow...!!W
    If the shop did the oil change they should have smelled the burnt plastic and a good tech will inspect the unit visually to see if all is well. I have to wonder about them or if it was just that tech. Did they do any other work at the time that could have caused this to happen like belt adjustment etc....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Apr 2017
    North Central Florida
    Quote Originally Posted by rkba101 View Post
    Sounds like something a Ride Now shop would do.
    What dealership was it ??
    May 2017
    Mesa, Arid-Zone-A
    Holey Smoke.....
    Semper Fi
    Dec 2016
    Default Name of Dealer
    Hope they even changed the oil?? I check the reservoir while the panels was off and it was empty.. Is this normal ??
    http://www.jacksonvillepowersports.com/
    10290 ATLANTIC BOULEVARDJACKSONVILLE, FL 32225
    There is a specific procedure for checking the oil. See your manual. One of the things is that the engine should be up to operating temperature.
    Apr 2017
    "Reservoir" ??? Oil ????
    Knowing what model and year you have would be helpful.
    You can put that information into your "signature" since there isn't another displayed field for it.
    INDIANA, USA
    Default Spyder Improvements
    Does anyone recognize the PART in the pictures? IS this at or near the drive belt? Is this a Factory spare Part?
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Quote Originally Posted by Little Blue View Post
    Its the oem belt guard. Looks like this when installed, but with 2 mounting bolts
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Dec 2016
    Default Appreciated it
    Hopefully I did that correctly and thanks for the advice.. Phil..
    My Ride --->>> 2013 ST-S SE5 <<---
    Bossier LoUiSiAna
    [QUOTE=nhoj;1332017]Its the oem belt guard. Looks like this when installed, but with 2 mounting bolts
    IMG-20130928-00096.jpg[/QUOTE
    IMG_3300.JPG Rear 1/2 belt guard, Pic of mine when it came off before first rear tire change
    (Around 15k m) think there was a bulletin about short stock bolts been a min can't say for sure, mine road up belt to drive sprocket for unknown miles, & I was fortunate enough that Jim at SmoothSpyder spotted it when he installed my dual mode back rest
    Sep 2016
    clark county indiana
    Default good job
    hey 101 , good job on the problem and locating the problem , oil might be about 8 ozs short , at this posting , maybe more ... { you keep this up an you will be able to step up to doctor ... }
    Sebring, FL
    Lurker here, My ride is a GW, Road Smith Conversion, and I can tell you, anyone that depends on a dealer without checking the work, beware. Oil changes, and some other things are difficult to check, but depending on most dealers is a no, no, Honda included. A really sad testimonial, when you pay $75/80 per hour for a fix or maintenance, but it is what it is.
    Nov 2013
    Oro Valley Arizona
    Most shops just hire kids off the street to do your work under the supervision of a real tech. Sometimes the real tech is having coffee and donuts and too busy to supervise so the kid does the best he can which is not good enough. This is the practice used by the largest chain of Can Am dealerships in the US. Bet you can guess who they are. As of this date 46 dealerships. We know the owners.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Active Member R FUN's Avatar
    Apr 2013
    Rocanville Saskatchewan canada
    My dealer even had kids setting up the new spyders. Mine the kid checked the oil before it was ever started, no oil showing so added over a quart of oil. After I test drove it I asked the salesman to show me the way to check the oil. The oil was nearly running out the top of reservoir. There were more horrer stories from set up to first service they did
    and have never took it back since, do all my own serviceing etc now.
    Roger
    2012 RT Limited
    Vertika Floor boards
    Painted rear fender & dash
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    Elka shocks and relocaters
    CB radio
    ISO hand grips
    Tric LED fender light
    Turn signal lights in mirrors
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Default I have this...
    Quote Originally Posted by nhoj View Post
    I just took a look and I have this same part on my 2016 ST-S...with 2 mounting bolts
    My question...is there a reason to replace this with some other belt guard at this point?
    Or is something like the Sypderpops (or similar) belt guard an "in addition" item that is worth adding?
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
