Results 1 to 14 of 14
    Dec 2008
    Syracuse, NY
    Default Need help with a fastener.
    I have a 2008 spyder. The plastic panels attach with a torx head screw into a metal fastener. I'm looking for a fastener which is similar, but only one sided. This is for locking a sheet metal screw in place. I just need to know the name of the fastener. It's not for the spyder.
    Default Not sure....
    Not sure but most fastener company online like "Dorman" carry a variety of them. I used the rivet on type but it depens on where it is going to be used. I also find a good selection at home depot in the specialty section. Auto parts may also have something to help you....
    ​2012 RS sm5
    Default THAT FASTENER
    I don't know how you can have a one-sided fastener, so I can't picture what you need .... But check McMaster Carr their assortment is pretty good .......Plus you can talk to human being about what you are looking for ...... Mike
    Aug 2012
    CO
    So you need a blind sheet metal fastener where you only have access from the front. Can it be a bolt? There are blind nuts and jack nuts for that.
    JLohPhotos
    2008 GS , Millennium Yellow
    Aug 2013
    SF Bay Area
    I’ve worked with What are called “tinnerman“ nuts which are clip on type with a threaded center hole. Also the left side of my ST uses a twist off type of attachment. You’d have to check the BRP for those parts.
    2021 F3 Ltd , Magna Red
    Aug 2013
    SF Bay Area
    Also, if you check out the belly pan for Goldwings, you’ll see a twist on fastener. For the life of me I can’t remember what they’re called.
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    If it's like the fasteners for the oil tank panel on a GS, they're DZUS fasteners, they need an anchor that fits.
    john
    Dec 2008
    Syracuse, NY
    That's what I'm talking about, tinnerman clips. The ones I'm used to don't clip on.
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    Are you looking for Dzus fasteners?
    https://en.m.wikipedia.org/wiki/Dzus_fastener
    Aircraft Spruce should carry them.
    Aug 2013
    SF Bay Area
    Yes that's it! Dzus nuts are used on the belly pan! Thanks! Different to tinnerman nuts.
    I've seen some RS/GS bikes converted over to DZUS fasteners: it's pretty darn slick!
    Aug 2012
    CO
    Quote Originally Posted by wyliec View Post
    You can buy a bag of those at Lowe's
    JLohPhotos
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by asp125 View Post
    I've got Lowe's near me. I'll check them out. Thanks
    Aug 2012
    CO
    They probably won't know them by the name Tinnerman clips. Ask for spring nuts. https://www.lowes.com/pl/Spring-nuts...are/4294710807
    JLohPhotos
