Results 1 to 17 of 17
    Member amhc59's Avatar
    Apr 2017
    Oak Harbor, Wa.
    Default R/H saddlebag won't open
    Hi! I have a 2011 Spyder RT SM5. For some reason I can't get the R/h saddlebag to unlatch and open. Cable doesn't feel to be broken. Any suggestions?
    Active Member robtdonna's Avatar
    Jul 2014
    Ellijay, Georgia, United States
    try pushing in on saddlebag as you pull handle.
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
    Default UNLATCHING
    Quote Originally Posted by amhc59 View Post
    On my 2014 RT the left side door has never worked correctly and has been adjusted numerous times ..... I just tap it ( hard ) on either top corner and then it opens ...... good luck .... Mike
    Sep 2017
    INDIANA, USA
    Default Saddle Bag
    ALL good tips, if you DID NOT make the mistake putting something BIG in the BAG. I put my big boots in and it caused the same problem. The FIX, they are still in 'THE BAG'. Maybe some one will let us know a 'FIX' . PS: Lucky for me they were my old BOOTS.
    Sep 2017
    INDIANA, USA
    Default Saddle Bag
    I KNOW, Sale Bike with OLD BOOTS.
    Northern Kalifornia
    Quote Originally Posted by robtdonna View Post
    Same goes for all the other latches on these 's. Don't get mad and do something you'll regret when you're out of warrantee.
    Were you able to get it open?
    If the above don't work--time to see the dealer. Mine did that too. It required a cable adjustment to fix the latches.
    Apr 2017
    Oak Harbor, Wa.
    All good ideas - I'll try them. What I'm afraid what happened is that my jacket liner was in there and got caught in the latch, keeping it from releasing.
    If that's the source of the problem: pushing in on the saddlebag may just buy you enough removed tension on the latch, to make some magic happen...
    Good luck!
    Apr 2017
    Oak Harbor, Wa.
    "If the above don't work--time to see the dealer. Mine did that too. It required a cable adjustment to fix the latches"
    So how did they get to the cables? Most the screws are hidden because of the lid being closed - can't remove the needed plastic.
    Sep 2017
    INDIANA, USA
    Default Saddle Bag
    I was told that this might be a very 'Expensive' operation. Like maybe a new R/H Saddle Bag or maybe in your case a used one. Good Luck and let everyone here know what happens. PS: I'M still waiting for a cost effective idea. So far nothing has work.
    I believe you get to the cable adjuster by entering from "under" the back Tupperware. I let the dealer mess with it. They did not charge me for it.
    Apr 2017
    Oak Harbor, Wa.
    The rains have hit for a few days so I'm at a stop on the door. Gonna try the back plastic next. Other ideas didn't do it. Thanks all....
    Sep 2017
    INDIANA, USA
    Default Saddle Bag
    GOOD LUCK.
    Sep 2017
    INDIANA, USA
    Default Saddle Bag
    OLD Boots Still in the R/H Saddle Bag. Dealer said this is NOT a Warranty Covered Issue. They did push and look But Nothing Would Open the R/H Saddle Bag.
    ENJOY YOUR LIFE WITH A SPYDER
    Sep 2012
    Stetson, Maine
    In the manual for a.2011 it says you can remove the cover below the hand grip by removing the 2.screws, unplugging audio cable from cover and you should be able to get at the latch with a screw driver. Good luck. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
