Results 1 to 19 of 19
Thread: Radio Antenna
    Jul 2017
    Woodbine, Iowa
    Default Radio Antenna
    Has anyone switched their long antenna on the RT to the short Scosche antenna from Wal-Mart.? I have purchased one but have not installed it. I was wander if you get as good of reception on the radio with the short as with the long antenna.
    2021 RT Limited
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Jan 2015
    southern WI
    Yup, I've switched to that stubby rubber antenna from Wally World for both of our RT's. Reception is just as good, possibly better.
    2021 RT Limited
    2016 RTS , Pearl White
    Jul 2017
    Woodbine, Iowa
    Default Antenna
    Quote Originally Posted by Mazo EMS2 View Post
    Thanks for the reply. I just purchased one today and did wander if the reception would be as good. I have a full cover that I do use once in while and it is hard to get it over the long antenna.
    2021 RT Limited
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Default ANTENNAE SWAP
    Quote Originally Posted by gerald37 View Post
    In case you haven't read " how to remove the antennae " ..... use a deep 7mm socket and a pair of vice grips to hold from slipping ........ remove all the thread sealer ( lok-tite ) from the antennae threads and as much as you can from internal threads ..... this will improve the contact between those metal parts, which is a very good thing ......good luck .... Mike
    Nov 2013
    Oro Valley Arizona
    Works great. After being stubborn about changing over all these years and breaking a few putting on my cover I did it. Can not believe I did not do this earlier.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Member Chappie's Avatar
    Nov 2017
    Castle Rock Washington
    Is this the antenna you speak of? I don't use the radio much and don't really care about reception but if it works ok I'm in!
    Antenna
    Thanks
    Ron
    Jul 2017
    Woodbine, Iowa
    Quote Originally Posted by Chappie View Post
    Antenna
    Thanks
    Ron
    That is the antenna I have. I listen to music through my phone with Sena but I do listen to my radio some.
    2021 RT Limited
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    too. Another vote on the pile. Used one when my original one fell off. Did not notice any difference in reception. But, the reception is kind of bad for radio in AK anyway. To many mountain ranges all over the place.
    Active Member Rookiespyder's Avatar
    Jun 2017
    Hanover Ont Canada
    I replaced mine as well with the one from Walmart. I like it for the looks and better reception.
    2015 RT Limited
    Vermont
    I replaced my long antenna 2 years ago, I now have a short antenna. Here is picture of mine: New Radio Antenna on 2014RTS-SE6 001.jpg I used a 7mm deep socket. I installed the antenna myself.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    On a 2016 RTL there must be a trick to it? I can't seem to get it off any words of advise thanks much
    2016 RT Limited , White
    Oct 2016
    Faribault, MN
    See BLUEKNIGHT911 (Mike's) earlier post. After removing the boot, find a deep well 7 MM socket, slide it over the end of the antenna and use a pair of Vise-Grip like locking pliers to grasp the outside of the socket and turn CC. They (BRP) put a lot of locktite on the threads and the originals are usually a bear to break free and remove. But you can.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    Default Which antenna is yours
    Deanna
    What make and model is your antenna? I have one of WM’s short flexible antennas but the reception is not good. I think yours is a bit longer and would be more beneficial. Thanks
    May 2015
    Liverpool, NY
    2016 RTL my rubber boot will not stay on so I bought a stubby one from Lamonster just can't figure out how to remove it mine flexes it's not rigid like 2015 and back. Mine is shorter than the one on a 2015 as well. I watched Lamonsters video as well
    Idaho
    A couple of years ago when my OEM antenna broke off on the Interstate in Kansas somewhere, I stopped at a WM and bought the Scosche shorty. I was not impressed. No better than the OEM, if even as good. I eventually took my old BRP CB antenna I wasn't using and put it on the radio side.
    Unless you have some overwhelming reason to get away from the OEM antenna, like Jack above, I say stick with it.
    2014 Copper RTS
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Hmmm your last statement has me thinking about putting a dab of dielectric grease on the threads
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    While that sounds like a good thing to do: that antenna needs to be solidly in place. The di-electric grease might just allow it to "loosen-up"; you'll have a fun time looking for it along the road...
    Vermont
    Quote Originally Posted by Cleg View Post
    I bought the short antenna @ Pitbulls, Item # 710005084, the boot item # is 708300156. In different parts of VT, the radio reception is ok( depending on the radio station).
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Apr 2012
    Queensbury, NY
    Default Thanks
    Deanna
    Thanks for the response... I’ll look into it. Hopefully here in NY I’ll be ok with that one...see you at Spyderquest!
