Results 1 to 10 of 10
    Apr 2017
    foley alabama
    Default rear tire 2016 rts
    do you have to change the seals when you replace rear tire.shop said you do and they will have to order them
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    ​what's a seal ??
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    May 2012
    Panama City, FL
    Are you referring to the tire valve? If it's in good shape probably not, however, I've always replaced mine, it's cheap insurance and may prevent problems down the road. Dale
    INDIANA, USA
    Default Rear Tire
    What all are they doing to your SPYDER? No seals in my rear wheel. What maybe the tire valve?
    Apr 2017
    foley alabama
    Default rear tire
    2 of them part #293200094
    Apr 2017
    Wisconsin
    Quote Originally Posted by mike1952 View Post
    Those are the wheel bearing seals in the wheel
    I would let them replace them, they must think they are bad for some reason. Plus they are not that expensive.
    Apr 2017
    foley alabama
    they replace them every time.but i never saw anyone do this
    Apr 2017
    Wisconsin
    Their technician or service writer / manager must think its wise for preventable maintenance. Seeing as thats the seal(s) protecting the bearings from the elements.
    Apr 2017
    Wisconsin
    If your thinking they are just trying to make some extra money, They surely aren't getting rich off of selling you those seals as they aren't that expensive. So I'm sure its just for preventable maintenance purposes.
    I think they're just trying to lighten your wallet. In my Green manual it does call for seal replacement when the wheel bearings are changed, which makes consummate sense, but not during a simple rear tire replacement IMO. I've had three tire replacements and have never been told the seals needed to be replaced. The dealership wouldn't pass up an opportunity to add a few bucks to the bill either. If the belt tension is correct the bearings and seals should last a good, long poke.
