Thanks Thanks:  2
Likes Likes:  0
Results 1 to 5 of 5
    Apr 2015
    Melbourne,Florida
    Default Trailer harness adapter
    I have an F3T Limited and a Bushtec trailer. I'm looking to buy an after market hitch and harness. Trailer has a 6 way flat connector while I THINK the spyder plug and play is a 4 way flat. Does anyone know of an adapter? Bushtec said they do not have one. I have checked on line and can not find one either.
    Dec 2015
    NE Ohio
    Not sure about a Bushtec but I made my own adapter for the Spyder harness 4-pin square to 4-pin flat on my trailer. What is the pin-out of the Bushtec?
    Active Member sylvester's Avatar
    Aug 2017
    arkansas
    I have a bushtec wired. Look up www.electricalconnection.com they will make you what you need. You will not be able to have a 6 plug connection 5 max the 6th one is for the inside trl light. you need to buy a 4 to 5 converter new isolator to match and leave out the BRP 2 to 3 harness not needed. I bought BRP's trl hitch removed the ball depending on what receiver hitch you had , I had a wing with slide in . I cut the square piece off and welded the pin with bar to the BRP hitch, hope this helps . I have a !7 F-3 T limited
    Active Member fencepost's Avatar
    Apr 2010
    Thorn Hill, TN
    Lewis @ Electrical Connection will be able to fix you up. You will need to get the bike end plug from Bushtec
    SpYderman
    Very Active Member Marker's Avatar
    Aug 2010
    Guelph,Ontario,Canada
    Bushtec sells a hitch and wiring harness
    2016 F3Limited Special Series Triple Black
