2014 RSS Rear Shock dimensions
HI everyone,
I am getting a rear shock made with low high speed comp rebound. As I am not able to dismount the shock myself, I took the trike to Quantum Racing, who have been able to measure rear shock as much as they could in situ. We still need width of the top of shock absorber (hidden behind metal boxed section) and bottom please.
Also any info on spring re length, spring rate etc will be helpful.
Many thanks for your help.
Best wishes
Babr
Hi Jerry, not able to see pics. but this data is gold for me. I am getting shocks done by Quantum Racing. http://quantumracing.co.uk/two-zero/ . They did setup on my last reverse trike. I am getting a two way set up on rear of RSS. Having read on F3S posts, spring rate is 350-400. You are right RSS is dual rate. Any info on spring will be great. Best wishes - Babr
See if this helps you see the pics:
If you're using Google Chrome, go to the three dots on the right side of the screen and click them. A drop down should appear. Hover your mouse over "More Tools," and when the next drop down appears, click on extensions. Go to the link towards the bottom that says "Get more extensions." In the search box, type "Photobucket Fix," and hit enter. Click the install button and once it's done, you should be able to see photobucket pictures again.
For FireFox users, click on the three bars on the right side of the screen, then click on add ons. Click search for "photobucket hotlink" and click install. Same result.
Spring Rate
Hi Jerry,
Re bottoming out, I weigh 150 lbs and wife 105 so never bottomed out. I will ask Quantum re height adjustable shock. They are awaiting info on stock springs, so if you have any data on rear spring rate, that will be great.
Many thanks again for all your help.
a video of my last trike with quantum shocks
Best
Babr
Babr,
Lower spring rate = 405 lb/in
Upper spring rate = 810 lbs/in
Cross over point happens at 705 lb loading (@ 1.74")
Are you keeping the Fox shocks on the front? If so, the spring rates on these are 181 lbs/in. I found them a bit weak and switched to 225 lb/in.
Hi everyone, hope all is well. I have been riding RSS in snow, cold and all through winters.
I will get new rear shock next week so will post pics soon.
Re front Fox shocks , I increased preload (6 rings from bottom test driven for 2 months), but have dialed back to 5 rings as the ride was mega harsh and probably my low weight (now 65 Kgs) didn't do any favours. The ride is more compliant now on bumps but very cushy on steering. I will sort fronts once been fully satisfied with new rear shock.
See you soon.
Thanks
Babr
RSS Shock pics
Many thanks Jerry and all folks here. couldn't have been possible without your help. Now needs some serious testing.IMG_4497.jpgIMG_4494.jpg
Many thanks again
Babr
