Results 1 to 4 of 4
    Member carob998's Avatar
    Coral Springs, FL
    Default Highway Peg Alternative RS-S
    Hi All;
    Installed these as highway pegs for the RS-S. Here's what I used each side:
    • 2 1/2" long x 1/2" dia S.S. bolt
    • 2 split washers
    • 2 - 2" square flat washers w/ two sided tape to better secure to bracket.
    • #7573 Magnum peg Mount by Kuryakyn
    • #7560 Trident Small Pegs by Kuryakyn
    Info: I weigh 160 lbs w/ a size 9 boot
    Just completed a 600 mile round trip and thought they worked well. A few items to note:
    1. Used just a few times to give old knees a break
    2. May not work with larger boot sizes
    3. Wifey can use driver pegs to stretch out for a little while
    4. A little bit "bouncy" when going over uneven pavement, but pretty solid otherwise.
    What you all think?? Likes or dislikes.
    Rory
    2016 RSS , Black
    Default Interesting....🤔
    Well done and a nice set up. just have to watch the weight on them. Those foot guards are not that sturdy but knowing that should work well...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Looking good.
    Coral Springs, FL
    Default Thnx
    Thnx. I only used it couple of times on the last trip and it worked well.
    You can also rest your heel on driver pegs and toe on added peg, so as not to put too much weight on the bracket if you're worried about bracket
    A little bit of forward foot position goes a long way.
    Rory
    2016 RSS , Black
