Results 1 to 12 of 12
    Member carob998's Avatar
    Sep 2017
    Coral Springs, FL
    Default Belt Pulley Sprocket Issue RS-S
    Happy New Year to everyone!! All of the very best for 2018.
    We just completed a 600 mile round trip last Friday into Saturday. At halfway point I noticed the belt on rear pulley (see attachments) appear to be slipping off. Upon returning home the belt position returned to its original position, or close to it.
    Info: Two-up w/ gear for two days and averaging 75-80 mph on the highway.
    I'm taking her in to the dealer tomorrow for review and fix. So my question is:
    Is there anything specific I should be telling the service dept to investigate?? Please advise.
    Thnx for your input.
    Rory
    2016 RS-S (2050 miles). Purchased in Sept 2017
    2016 RSS , Black
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Quote Originally Posted by carob998 View Post
    Rory
    you didn't just back the bike up a few feet before you noticed it did you? because the belt will make some wild moves when backing up.
    Sep 2017
    Coral Springs, FL
    No. I drove head first into a parking space.
    Rory
    2016 RSS , Black
    Default Curious...🤔
    did you back up at any point before pulling into your parking slot..? The fact that it went back to normal or close makes it seem to be the issue. Never-the-less would be good to have it checked out as there is a dusty red coloring on the belt and could have a front pulley issue causing this...
    ​2012 RS sm5
    Sep 2017
    Coral Springs, FL
    Default Thnx
    Perhaps its my aging mind playing tricks but I can't remember doing any reverse maneuvers. I will have checked out tomorrow nonetheless.
    2016 RSS , Black
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    If you grab the pulley top and bottom can you feel any movement by rocking it side to side? There is a double row bearing in the pulley. They have been known to be a 'loose' fit within its housing causing the belt to move a bit. Get the torque on the front pulley retaining bolt checked also.
    The best substitute for brains & knowledge is....................silence.
    Sep 2017
    Coral Springs, FL
    Default Checks....
    All, thnx for the replies.
    Did a couple of things:
    • Wiped parts of the belt w/ a clean paper towel and no evidence of "red dust", just dirt. Could it be the camera that gave the belt an unusual tint?
    • Rocked rear pulley...no movement
    • Tried to recall any reversing....nothing came to mind.
    Will have service dept look at:
    1. Front pulley (wear)
    2. Torque setting of front pulley bolt, and
    3. Drive belt tension
    If anyone can think of other checks they can do, please chime in.
    Thnx a bunch!!!
    Rory
    2016 RSS , Black
    Default NOT A BELT CHECK PER SE'
    Thnx a bunch!!!
    Rory
    A Syder owner made a video ( it's on U-tube ) of what your belt is doing ALL THE TIME you are driving down the road ...... guess what ??.... the belt moves side to side on the rear flange constantly .... After I watched the video ( about a dozen times ) I was no longer concerned about this type of movement. I try and check where my belt is after I stop for a break and very often it has moved from the last time I looked ........... Mike
    Nov 2015
    Chardon, OH
    I know Mike. But a lady was on here about a year ago with an almost identical picture. Her front sprocket fell off in the middle of the road on her way to the dealer. Best he gets it looked over just to be sure.
    Doug
    ”Freedom is not a loophole”
    Dec 2009
    West Oz
    Ignorance is bliss - until ya drive pulley falls off.
    Sep 2017
    Coral Springs, FL
    Default Appointment
    Thnx all for your input.
    Appointment on Saturday morning. I'll let you all know the outcome....stay tuned
    Rory
    2016 RSS , Black
    Sep 2017
    Coral Springs, FL
    Default Tension
    All, ok dealer says belt tension was out of spec and they corrected that.....................I can only hope.
    I took a pic of the belt position on the rear pulley after dealer "correction" and will keep any eye.
    Thnx again for your feedback.
    Rory
    2016 RSS , Black
