Check Engine on
After my 2011 RT sat for about two months with an almost empty gas tank, I added two gallons of very old gas (at least 6 months old). When I headed to the gas station to fill up with fresh premium gas. the "Check Engine" light came on. I checked for codes and found P0171 & P0174 ( fuel injection or fuel problems for both cylinders). I suspect that the stale gas caused the codes. Any suggestions?
lhilsa
Reno, NV
Gas goes bad
From Owner's Manual:
"NOTICE: Always use fresh gasoline. Gasoline will oxidize; the result is loss of octane, volatile compounds, and the production of gum and varnish deposits which can damage the fuel system."
I'd contact your dealer. Most likely your fuel injectors got clogged. You can try putting one of those fuel injector cleaners in the tank and topping off with Top Tier gas. There are a lot of fuel system cleaners out there.
Next time you plan on storing your Spyder for a while make sure you pour some fuel stabilizer in the tank and top it off. Empty tank will rust.
This is the stabilizer I use:
https://www.amazon.com/gp/product/B00D3IEIH2
Fuel system cleaners I use:
https://www.amazon.com/dp/B00092893E
https://www.amazon.com/dp/B0002JN2EU
I hope that helps.
Lets see....
I would drain the tank and fill it with a good source of gasoline with some injector cleaner added and do some ryding preferably fast spurt. This should help clean out the system. Repalce the fuel filter as well as they do not clean up well...May take a tank or two to get you back to normal....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Partly plugged fuel filter or injectors.
I would drain all the gas. Replace the fuel filter. Fill with fresh fuel and add some Seafoam.
Uh... you did what ? Maybe we'll try that one on the lawn mower,
but on the "near 30k" Spyder?
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
