Results 1 to 6 of 6
    Dec 2017
    Indio, CA
    Default Broken purge solenoid
    Hi-
    I decided to do the canisterectomy today and I ended up breaking the lower plastic connector on my purge solenoid right at the base. It broke in one piece, so would epoxying it work temporarily until I can get a new one?
    The part says Bosch 0 280 142 470...I am having trouble finding it online. Is there a different part number I could find at a local parts store or car dealership? The nearest Can-Am dealer is 100 miles away.
    Any thoughts or suggestions would be great
    Thanks
    Jeff
    2008 GS SM5 , Yellow
    Default Try this
    709000443 purge valve $48.99 at cheapcycleparts.com. This is for a 2008 GS...
    709000413 rollover valve $35.99 located on the tank
    Don't see any solenoid
    ​2012 RS sm5
    Dec 2017
    Indio, CA
    Thanks Chupaca
    Do you think epoxying the broken one will work in the meantime?
    Default Sure....
    Should be fine, just let it set well. I usually use a soldering gun to weld the break and then apply the epoxy so it has rough edges to latch onto...
    ​2012 RS sm5
    Dec 2017
    Indio, CA
    Yep, it is the purge valve
    Aug 2007
    Greeneville, TN
    Why do you want to retain the purge valve anyway? If you are removing the canister. The purge valve would serve no function.
