Results 1 to 7 of 7
Thread: coolant
    Apr 2016
    ontario cda
    Default coolant
    do spyders come with antifreeze in the coolant for canadian winters for those of us who store at home in the garage
    Default Oh Yeah..!!
    All spiders come with antifreeze mix in them. Ask akspyderman in Alaska he knows winter...
    ​2012 RS sm5
    All five of mine have come with the factory anti freeze mix. Mine are safely parked in a heated garage in winter at 50 degrees. Have never had a coolant or overheating problem. That's all I can say.
    Sep 2017
    INDIANA, USA
    Default Coolant
    Did you Buy from a local dealer? Did you buy it in AZ, USA and then take it to Canada? Did you buy it used and maybe someone DID a "oh no"? By the rules, the dealer should adjust the coolant /anti-freeze as per the regions Lowest temperature. Someone could have missed this, but generally most Dealers DO it RIGHT. MY 2 Little Blue
    Sep 2017
    Durham,Maine
    Quote Originally Posted by harry1025 View Post
    Every four stroke engine made comes with antifreeze in it as far as I remember. It not only transfers heat better, lubricates and protects the inside of your engine, better than water, it keeps it from freezing like a brick in the cold. Why do you ask the question?
    2012 RTL , Pearl
    Jul 2014
    Mint Hill, NC
    Mikey's in the bulls-eye. Remember also that the antifreeze in the cooling system raises the boiling temperature, a major benefit in hot climates. You should never use just plain water in an aluminum engine.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Apr 2016
    ontario cda
    Default thanks
    just satisfying my curiosity i do appreciate the responses thanks
