Results 1 to 14 of 14
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Default not for the meek
    all apart for plugs/wires and JT's air cleaner assembly. only a fuzz under 14,000 miles but I think this might be a good time to remove the rocker covers and check some clearances.IMG_6434.JPGIMG_6435.JPGIMG_6436.JPG
    Default Choices, choices
    While your there and in the mood....and you have a V-Twin... most don't or have not needed any adjustment at that mileage and I have almost 40,000 and still good but be sure you have what you need to do it...busy man with fun projects...enjoy..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2014
    Benson, NY
    That nightmare is still fresh in my mind...I did it to mine about 3 months ago. The scars on my hands are barely noticeable now.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    10 points for bravery. Some of those jobs can be daunting. The is not a user friendly machine when it comes to working on them.
    It is extremely rare that you will need cam/lifter/shim adjustment. Even after 50k it's not common to need it.
    Faribault, MN
    Kudo's to you (oh mighty mariner), I just looked at changing my '13's air filter and didn't even try it. I've removed the frunk, all the tupperware, and the rear tire, but getting under that tank/dash is too tight for my meaty paws... I'm gonna pay a dealer for that job....
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Very Active Member spacetiger's Avatar
    N. Va
    Default A suggestion while it is apart.
    While you have it apart, I would suggest you wrap the exhaust to keep the heat in check.
    Most have used the standard exhaust wrap but I found the 1" or 2" thick ceramic blanket material to be superior in heat insulation. It can take 2,300 degrees F all day no issues, much easier to put on, and is cheap; here is an example on ebay for some 2" thick stuff for $20.:
    https://www.ebay.com/itm/Ceramic-Fib....c100005.m1851
    Once on, I used an aluminum dryer duct cut lengthwise to encase the ceramic blanket. It looks clean and really cuts down the heat.
    A pic of the job on my 2013 STL
    Jerry
    13 ST Limited F/R suspension, Corbin, GIVI top case
    16 Vespa Primavera 150: Stock
    16 Piaggio BV350: Suspension, braking mods in work
    14 HD XL1200T: F/R suspension and brake mods; Corbin saddle and bags
    09 Aprilia SC250: F/R suspension and minor brake mods
    97 Honda PC800: F/R wheels, F/R suspension, and F/R brake Mods; Corbin saddle
    90 CB-1: In work, long term project
    89 Honda NT650: F/R suspension; Corbin saddle
    Sep 2016
    clark county indiana
    Default good job on the " take down "
    Quote Originally Posted by quasi View Post
    hahahhaa , need to ride in the parade with all the skins off ( I give up , where are the plugs ? )
    Invalid Emails
    Oct 2015
    front plug just forward of the throttle body on right side of head. you can see the ribbed loom on the plug wire. rear plug on left side of the engine. worst part was getting the airbox base out as I didn't want to remove the right lateral stabilizer bar. it was tight but it came out with some persuasion. the entire airbox assy is out including the resonator portion.
    Durham,Maine
    They look so sad without all the Tupperware off them, like a wet puppy! Your a better man than I, Good luck!
    2012 RTL , Pearl
    Dec 2015
    South Carolina
    Default This is in my mind for next years winter upgrade. Here is this years plan.
    I have a 2012 RTSE5 with 18k on it. I took the bike from my house here in Indiana to my daughters house in Rock Hill SC. My winter projects are
    Bleed brakes, check pads / wear.
    Oil Change - check all fluids.
    Replace rear tire (have General Altimax R43 ready to install.
    Replace plastic belt tensioner with DOC's metal one.
    Install Elkas on all three
    We were lucky enough to win the bid on a pair of custom hubs at last years Spiderfest - so I added new General Altimax R43's to these, and they are ready to mount on the bike.
    Install new seal on frunk.
    I am not a mechanic, or experienced on this mechanical stuff. But I don't think I'm to thick in the head, plus there a great how to videos to follow for most of this stuff. Plus I am excited to get south and start working on my bike.
    I would welcome any suggestions the more skilled have to offer.
    Next year, I want to tackle plugs, wires, air filter
    Aug 2008
    MA & NH
    X rated nudity ??
    Nekkid Spyder!!
    Invalid Emails
    Oct 2015
    Quote Originally Posted by spacetiger View Post
    Jerry
    thanks, gonna order some of this. splitting aluminum dryer duct is a good idea.
