Results 1 to 12 of 12
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    Default Battery Replacement - CCA's
    This is probably one of those topics like oil and tires that will raise all sorts of opinions... but, what should the minimum Cold Cranking Amps be for an RT when looking for a new battery?
    I have a 2014 RTS, and have never had any issues with the battery, but approaching four years old, I think it prudent to consider a new battery in the spring.
    I see a variety of the AGC (sealed) batteries from name-brand manufacturers, with an equal variety of listed CCA and prices!
    Does anyone know what the OEM battery's tech-spec was for CCA's?
    Bob
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Quote Originally Posted by Bob L View Post
    Battery Family: High Performance, Maintenance Free
    Battery Type: YTX24HL
    Must use Factory Activated battery, due to battery tilt possibly causing leakage.
    Voltage: 12
    Capacity: 21
    Dimensions: 8.125" x 3.4375" x 6.375"
    Weight: 17.5 lbs.
    Metric Dimensions: 205mm x 87mm x 162mm
    Metric Weight: 7.95 kg
    Polarity:
    Acid Volume: NA
    Amps: 2.1
    C.C.A.: 350
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Active Member kbwitt's Avatar
    Jun 2015
    AZ
    Default Battery replacement on 2014 Rt
    Go on line and shop, I saved $100.00 from what dealer wanted. Go ahead and order one you are going to need it soon. Can even put into the frunk till needed. It's any easy change out and any tools needed are under your 21014 RT Seat
    Kenn
    Sep 2014
    USA
    Lamonster garage has batteries that you need.
    Oct 2014
    Massachusetts
    Quote Originally Posted by kbwitt View Post
    Kenn
    That's what I've been doing... planning a spring trip and figured I would change it out before it gives me any trouble.
    Bob L.
    www.rk-mass2.org
    Default There you have it....
    350 CCA. Though during the many years of working on motorcycles, managing parts departments I have not found a better battery than the YUASA. Most used oem battery around. Remember these machines have a lot of electrical components with large loads and draws. My current battery is 6 years old with no issues (except when the kids leave the lights on) stick with the specs in the manual...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Active Member sylvester's Avatar
    Aug 2017
    arkansas
    i got my yuasa through amazon 99.00
    Default OEM BATTERY
    I still have mine ( 2014 RT ) that because I no longer trust it ( it wasn't charged properly when new **** ) .... I bought a Lithium jumper pack ... ( $45.00 on E-bay ) as my Back-up ..... because frankly no one can tell you for sure when your present battery is going to CRAP -out .... it could last another 4 years or more ..... $45 is well spent because it does lots of other things beside " just waiting to be used " .................jmho .... Mike
    Oct 2017
    N.E. Ohio, USA
    Are these specifications for a 998 or 1400?
    Quote Originally Posted by nhoj View Post
    Voltage: 12
    Capacity: 21
    Weight: 17.5 lbs.
    Polarity:
    Acid Volume: NA
    Amps: 2.1
    C.C.A.: 350
    Very Active Member Larry rt's Avatar
    Jul 2013
    Vestaburg Michigan
    Question
    Is the cca 350 cranking power? I saw some replacements showing 300. Does that make a difference?
    Sep 2014
    USA
    50 less Cold cranking amps. So if your in a colder area that 50 A cold help with starting
    most people don't ride in the colder temps anyway and put the Spyder in storage
    Apr 2012
    Quote Originally Posted by daz View Post
    That's the spec for the OEM (Yuasa) battery used in all spyder models since 2008.
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
