Results 1 to 12 of 12
Thread: Camera Mounting
    Dec 2016
    Iowa
    Default Camera Mounting
    Pulling the trigger on GoPro5 Black camera tomorrow, can it be mounted on dash for easy access or does the windshield cause distortion?
    I saw someone's video with a wooden tripod which put the camera a foot or so above helmet which looked really good not sure how complicated that would be.
    Other mounting suggestions, do not think I wish it mounted on my helmet.
    2016 RT Limited , Black
    Nov 2017
    Gaithersburg, MD
    Default Gopro mount
    Quote Originally Posted by Tyris View Post
    Hi,
    The ram mount from Lamonster and Arkon 25mm Swivel Ball to GoPro HERO Lateral Prong Pattern Adapter for GoPro Mount would be good option. I have these on my 2017 RTL SE6 for mounting Gropro hero 5 black, which work great .
    Good luck and happy holidays!
    Best,
    Baski
    Aug 2012
    CO
    I've shot video both through a windshield and without. I prefer the without version. The clarity through a clean windshield is acceptable, but certain light and weather conditions (rain) cause spurious reflections on windshields.
    JLohPhotos
    2008 GS , Millennium Yellow
    Nov 2017
    Gaithersburg, MD
    Quote Originally Posted by asp125 View Post
    Can you please provide the link for these videos, if they are available?
    Thanks and I appreciate it.
    Active Member bushrat's Avatar
    Apr 2017
    Peterborough, ON, Canada
    When we bought our 2017 F3L, we were given a Cyclops 360 camera, similar to GoPro, by BRP, as a sales promotion bonus. We faced the same dilemma - where/how to mount? The problem sort of solved itself when we switched from the short, stock windshield to a 'tall boy'. This meant changing the windshield mounting brackets; the 'tall boy' brackets have an open arch. The camera came with 4 or 5 mounting options, one of which was a clamp affair with ram ball meant for use on handle bars; we were able to clamp this to the bracket arch on the right side of the windshield (could work on left side just as well). The camera sits just outside and clear of the windshield; haven't used it yet, but hope to do so shortly. This mounting method seems secure, and within easy reach of pre-installed cables in glove box.
    [SIGPIC]
    2017 F3 Ltd. Intense Red Pearl/Metallic Black topside
    2017 F3Limited , lowered brake pedal Intense Red Pearl w. Metallic Black topside
    Oct 2016
    Faribault, MN
    I'd check out Pierre Poliquin's videos on Youtube and at Spydertv.net, pretty sure he still uses GoPro's and has the tall tripod system on an RT that shoots over the drivers head.
    His
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Dec 2016
    Iowa
    Quote Originally Posted by DGoebel View Post
    His
    Yeah, I did and he's digging up some pics for me, I really liked the viewpoint although the ability to remove and stow tripod would be a great plus. Although I's guessing buying tri-pod system would cost as much as the camera itself and that's just not going to happen.
    Apr 2016
    Massachusetts
    Default Still trying to get it right
    I have tried various places to mount my GoPro on my 13ST. Behind the windshield results in distortion when the sun hits it. In front requires mounting on the front panel that results in vibration. I find that the helmet mount gives the best view without much vibration and distortion. Also it allows views and recording when stopped without moving the camera.
    Dec 2016
    Iowa
    On the verge of buying F4 windshield with the vent in the center and thinking there may be a way to shoot through the vent.
    Aug 2012
    CO
    Quote Originally Posted by BriteSpydie View Post
    Apologies for the poor quality, this was an older video and loss of detail from compression for Facebook
    Notice the lens flare but in addition the reflections off the dashboard and brake fluid reservoir
    https://vimeo.com/248725474
    vs this one mounted on the Spyder's fender under the mirror. Still a bit of lens flare but no spurious reflections.
    https://vimeo.com/68269331
    JLohPhotos
    Aug 2013
    SF Bay Area
    I mounted my Garmin Virb on the mirror mount so it sticks out in front of the windshield my ST-L. I had a safety strap attached to the windshield mounts just in case it popped off.
    https://youtu.be/W_CMs2X2SYY
    2021 F3 Ltd , Magna Red
    Nov 2017
    Gaithersburg, MD
    Awesome!
    Thanks
