Results 1 to 8 of 8
    Dec 2017
    South Arizona
    Default Noise under mild acceleration
    Mary Christmas folks!
    I have a issue which begins at about 4000 rpm, the engine makes a clicking sound under mild acceleration, sound to me like a lifter click or rod noise, which I doubt as the thing just turned 8k miles. If I back off the gas it stops and doesn't get worse if I hit it harder. Anyone notice that or have ideas? I've a '13 STS SE5.
    Maek
    Default Interesting....🤔
    It would seem to be fixed to that rpm. Rods, lifters, valves etc would be dirctly connected to the rpm at any level. Is this a rolling 4000 rpms or engine only in netural rpm noise..? we usually start by checking oil levels and condition. The Se5 clutch is fully engaged about at that rpm could be in there.
    ​2012 RS sm5
    Bossier LoUiSiAna
    & wouldn't hurt to remove the Tupperware just to see if anything may be loose & the clicking could be more of something with a vibration issue, that if you can hear you should be feeling even more accurately.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    Default shop
    if any of these above ideas do not work , or help , take that baby too the shop , let them have a look , { it sounds like the lifters from the description }
    Dec 2017
    South Arizona
    Quote Originally Posted by youngers View Post
    Yup talked with the service manager. Goes to the Shop next week.
    Dec 2017
    South Arizona
    Quote Originally Posted by BrandyMB View Post
    Dealer checked it out and said that noise was normal for that type engine. I guess I'm just used to big twins like HD and Victory. All well, will pick it back up tomorrow.
    Very Active Member ingramwc's Avatar
    Oct 2008
    Kingsport, TN
    I have the same model, no funny noises from mine.
    Current ride: 2013 Circuit Yellow ST-S SE5
    Default DEALERS
    Unfortunately dealers ....LIE ...... especially when they don't have a clue ..... I would try and find someone with a V-twin engine and compare .... It's not going to matter wether RS - GS _STetc, or manual or SE tranny ..... You should both have the same exhaust tho ...... jmho ..... Mike
