Results 1 to 25 of 25
Hybrid View
    Sep 2016
    surfside beach
    Default had to charge the canam spyder rt help?
    would not start after about 5 days or so / 2ed time .my battery tender charges at 8 amps i use it for my bike , and a 2 amp charger for the canam rt so any one know any thing sure use the help .thanks electricman
    Northern Kalifornia
    Tighten your battery terminal leads tight. How old is your battery. Maybe take it out and load test it.
    Sep 2016
    surfside beach
    Default electricman i all ready tigten them chsrged for 3 hour like i said 2 amp and started
    iall ready tighten them charged for 3 hour like i said 2 amp and started , my first idear was some thing was draining the battery. so i will try that its just geting to it LOL thanks for info
    Sep 2016
    surfside beach
    Default not starting
    are you in s.c. we are.
    Default Bummer....
    First off what year is your RT..?? Would help tell the age of your battery. check all your ground and terminal connections. Now you mention an 8amp and a 2amp charger. We're they connected to the battery during the 5 days..?? You should have a tender or maintainer you can hook up when not ryding but not a charger. Depending on what add ons you have and even if none RT's tend to need the tenders. You should also get the battery tested have seen them last from 3 to 7 years depending...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Sep 2016
    surfside beach
    Default electricman
    ////// the book said to use 2 amp charger so my two 2 amp is not a tender i will get one and also get it checked thanks
    Sep 2016
    clark county indiana
    Default battery charger
    took out all the photos of battery maintainer --- 8 was to much
    Sep 2016
    Default dang posted to many
    I purchased the battery tender jr. also have a -- ctek maintainer --- the ctek has battery post terminals with led lights on the end , gives an idea of how much juice you have in the battery , green / yellow/ red green is great ( just got back from a ride ) yellow is at or around 60 % to 80% battery life / red plug it into the charger this is the photo of the l-e-d- lights on the battery side ( see that green light is on )
    Sep 2016
    surfside beach
    Default battery issues
    i only used the 8 amp one time in the paST 2AMP THE OTHER DAY and i was able to start it going to try starting it today < i got to see how to get the battery out in my repair man-thanks
    Apr 2017
    North Central Florida
    Quote Originally Posted by electricman View Post
    AND.....you still haven't told us how old your RT is.......or how old the battery is.
    It is highly likely that your battery has just reached the end of it's useful life.
    After you get a new battery installed, which has been fully charged first, you need to measure the battery voltage with the bike running.......to be sure your charging system is working.
    A healthy battery should easily sit for a couple of weeks without any kind of charger attached.
    But if you must, a fully automatic one is required.
    The total capacity isn't that important because that is under worst conditions and if it really is automatic, the charging rate won't get anywhere near the max. capacity of the charger.
    Jul 2011
    Mitchell, Ontario, Canada
    What model is your Spyder?
    What year is your Spyder?
    What modifications or accessories do you have?
    How old is your Spyders battery?
    When was the last time the battery was load tested?
    What is the system voltage, at the battery, with the engine running?
    Inquiring minds want to know.
    Sep 2016
    surfside beach
    Default battery
    SARRY IT IS A 2011 CANAM SOYDER RT WITH LES THAN 6.000 MILES
